Rear integra trailing arms in a civic??
Will rear 94'- 01' integra trailing arms fit a 96' civic ex? trying to do a rear disc conversion. What would i need? Thanks for the help.
Re: Rear integra trailing arms in a civic?? (GserpleaSR)
yes it fits.
all 94-01 integra and 92-00 civic rear trailing arm is the same
if your car has abs, make sure you buy ABS rear discs, or else you will have an ABS light.
im doing a rear disc on my 99 civic ex too...make sure to have the brake lines and e brake cable...the master cylinder and booster is a option ...so if you cant get a hold of it...its fine...i'm going to use my stock MS and booster...i have the integra MS but still have to pick up the booster...
For my swap I plan on doing this weekend I have:
The rear trailing arm assembly out of a 94 Integra.
trailing arms, calipers, hubs, etc.
New rear pads and rotors
New brake hoses for the rear, your old ones won't bolt up to the integra caliper.
Ebrake cables from a 99-00 Si, the ones from the Integra will work with a bit
persuasion.
Proportioning valve from a 99-00 Si
New brake fluid, you might as well bleed the sytem until it runs clear.
I think thats it. Good luck with it.
persuasion.
mp5o
12
07-14-2005 04:13 PM
unknown0001
14
08-30-2004 09:00 PM
