check engine light need some good help
i already searched my best
here are the codes
6 water temp sensor
17 vss speed sensor
22. vtec pressure valve
water temp is shows correct on the cluster
the speed sensor works its tell me my mph
and vtec preussure valve i think this happen after my buddy put the vtec contoller but i think i can doble check his wire if some one tells me with wires go to which
thanks again
here are the codes
6 water temp sensor
17 vss speed sensor
thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 »</TD></TR><TR><TD CLASS="quote">i already searched my best
You do know that there are 2 sensors for the water temp, the one right next to the thermostat , is used by the ECU. The one that attaches to the head, goes to your cluster
i think 3 buddy one on the thermostat and two on the head the one for cluster and antoher for comething else but it reads water temp sensor but evertyhing works good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 »</TD></TR><TR><TD CLASS="quote">i think this happen after my buddy put the vtec contoller</TD></TR></TABLE>
I have my money on wiring issues. Put the car back to stock, clear the codes, and see what happens.
