Radiator leaked coolant but from where?! Baffled.
Ok so heres the story.
I buy an LS about 2 weeks ago, installed myself, and it ran "ok". For a while i had idle problems, like at a stop sign, it would idle from 3000 to 2500, then back to 3000 again. O yea it also had a little sputter (put put sound). I dunno why it did this. Newho i thought it would stop after running it in for a while.
2 weeks later the sputter didnt stop (sputtering doesnt mind me, but maybe i did something wrong?) and the idle went down to a consistant 2000.
Ok so im on my way home, merging from the 5 freeway to the 22 sloped on-ramp in traffic.. My car is idling at 3000??? Wtf? Tried putting it in 1st gear w/o gas to see if it would move... it did not. Neway so im driving, and then all of a sudden my the temperature skyrockets. I pull over and pop the hood.
What i see is my overflowtank squirting lots of coolant from underneath it? or somewhere down there. I check for fluids coming out the hoses but i didnt see anything at all. Inside the tank was massive pressure and hot coolant. I open the radiator cap and there goes a massive coolant explosion. So i fill her up, used a whole bottle of rad fluid (rad was almost completely empty) and got home. Idles at 1500 now... seems normal.
Will it stay like this? Should i be expecting the same problems in the next few weeks? Ne1 know whats going on here?
again i did not see any radiator leaks from hoses...
before i think the radiator was leaking, so what i did was buy that NO LEAK crap, and the radiator was fine... for a while i guess
If it IS the radiator, HMOTORS screwed me over again. The first one they gave me was completely broken, it was like i poured radiator fluid thru a big *** straw.
And so i had to go there to replace it. I guess it was nice of them to replace it free of charge, but the valley is so far from me.
Radiator coolant is not cheap my friends! I have probably spent about 20 dollars on it already for those 2 radiators... blah. Water is my new frend.
Ok today on my way to school car was idling around 3000 RPM. I have no clue what it is.... Someone please help me... friends say vacuum lines, iavc, pvc, blah blah, but dont know how to check it.
Someone outthere help!!! i think also that becuz its idling so high its wasting and burning alot of my coolant in the radiator? Any advice out there?
ok so i fixed the idle... it was my throttle body cable, it was set on too tight haha
heres a pic of my dirty *** coolant stained engine bay
camera phone is only 10% accurate of its dirtyness... believe me
Bleed your coolant system to make sure coolant is actually going through the radiator. Does your fan turn on?
There should be a bleeder valve right by the head and the block on the left (pass) side. Let the car run for 10-15 mins with the bleeder open and you should see bubbles come out and keep doing that until you see a full stream, then close the bleeder and then fill the radiator.
Also dont use water, water = rust inside the block. Anti Freeze = prevents rust.
phoxking
Apr 4, 2011 09:03 PM
blue89hatch
Sep 6, 2008 11:12 PM
BrokenRex
Oct 20, 2005 05:52 PM
SeaBass
Dec 18, 2003 03:27 PM
