TurboXS Standard and High Performance BC differences in spool times?
Old Aug 26, 2004 | 10:58 AM
LudEcrous's Avatar
Default TurboXS Standard and High Performance BC differences in spool times?
i'm currently running a TurboXS standard manual boost controller at around 13psi..would switching to the High Performance one make a difference in spool times?
has anyone had experience with the two?
Old Aug 26, 2004 | 11:18 AM
underpressure02's Avatar
Default Re: TurboXS Standard and High Performance BC differences in spool times? (LudEcrous)
I would say no b/c your boost controller has nothing to do with how fast your turbo spools. All it does it tells your wastegate when to open and close.
Old Aug 26, 2004 | 11:30 AM
rmcdaniels's Avatar
Default Re: TurboXS Standard and High Performance BC differences in spool times? (underpressure02)
A checkball type controller keeps the wastegate from seeing any boost until the desired pressure is reached. Without it the wastegate will open up a little bit early when it sees partial boost, increasing spool time.
hold your breath
Mar 6, 2007 07:47 PM
teamrocket si
Feb 10, 2002 02:27 PM
Mikex25
Aug 16, 2001 03:44 PM
