Hallman Boost Controllers - In stock! The best manual boost controller on the market!
Hallman Pro Series Boost Controller
Hallman Boost Controllers have long been the industry staple for amateur and professional turbo racing enthusiasts. These new Pro Series Kits are some of the best looking boost controllers we've seen, and with Hallman quality and performance backing this product. Be sure that it will perform. The new adjustment system does not require a lock nut to keep it in place, simply adjust the **** and it stays there. Also if the **** is adjusted all of the way out it cannot come out of the controller. This new feature and design provides for a perfect overboost system since none of the internals can be lost since there is nothing that can come out of the controller. You cannot loose your adjustment **** anymore because of vibration or forgetting to tighten the lock nut like on the old style adjustment ****.Dont make the mistake of buying plastic or gimmicky boost controllers when this one is the only one you will need!!
$100 Always in stock
ADJUSTABLE INSIDE THE CAR!
Hallman Boost Controllers have long been the industry staple for amateur and professional turbo racing enthusiasts. These new Pro Series Kits are some of the best looking boost controllers we've seen, and with Hallman quality and performance backing this product. Be sure that it will perform. The new adjustment system does not require a lock nut to keep it in place, simply adjust the **** and it stays there. Also if the **** is adjusted all of the way out it cannot come out of the controller. This new feature and design provides for a perfect overboost system since none of the internals can be lost since there is nothing that can come out of the controller. You cannot loose your adjustment **** anymore because of vibration or forgetting to tighten the lock nut like on the old style adjustment ****. Dont make the mistake of buying plastic or gimmicky boost controllers when this one is the only one you will need!!
These new Evolution kits allow you to adjust boost from inside the cockpit, combining the ease of use like an electronic boost controller, without any of the hassle or headache.
$175! Always in stock!
prostreetonline
Dec 9, 2006 04:12 PM
prostreetonline
May 11, 2005 09:21 AM
prostreetonline
Oct 22, 2004 08:24 AM
