Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Boost Controllers - In stock and ready to ship!
Old Oct 16, 2004 | 01:47 PM
prostreetonline's Avatar
Default Boost Controllers - In stock and ready to ship!
Hallman Boost Controllers have long been the industry staple for amateur and professional turbo racing enthusiasts. These new Pro Series Kits are some of the best looking boost controllers we've seen, and with Hallman quality and performance backing this product. Be sure that it will perform. The new adjustment system does not require a lock nut to keep it in place, simply adjust the **** and it stays there. Also if the **** is adjusted all of the way out it cannot come out of the controller. This new feature and design provides for a perfect overboost system since none of the internals can be lost since there is nothing that can come out of the controller. You cannot loose your adjustment **** anymore because of vibration or forgetting to tighten the lock nut like on the old style adjustment ****.Dont make the mistake of buying plastic or gimmicky boost controllers when this one is the only one you will need!!
$100
CLICK HERE TO ORDER
Old Oct 16, 2004 | 01:48 PM
Default Re: Boost Controllers - In stock and ready to ship! (prostreetonline)
Hallman Pro Series Evolution Boost Controller
Hallman Boost Controllers have long been the industry staple for amateur and professional turbo racing enthusiasts. These new Pro Series Kits are some of the best looking boost controllers we've seen, and with Hallman quality and performance backing this product. Be sure that it will perform. The new adjustment system does not require a lock nut to keep it in place, simply adjust the **** and it stays there. Also if the **** is adjusted all of the way out it cannot come out of the controller. This new feature and design provides for a perfect overboost system since none of the internals can be lost since there is nothing that can come out of the controller. You cannot loose your adjustment **** anymore because of vibration or forgetting to tighten the lock nut like on the old style adjustment ****. Dont make the mistake of buying plastic or gimmicky boost controllers when this one is the only one you will need!!
These new Evolution kits allow you to adjust boost from inside the cockpit, combining the ease of use like an electronic boost controller, without any of the hassle or headache.
$175
CLICK HERE TO ORDER
Old Oct 16, 2004 | 01:49 PM
GReddy Profec B Spec II
LCD screen to monitor boost pressure in real time.
Readout now in kPa or PSI.
Control boost up to 43 psi (This may vary on different turbo systems)
There are 2 preset settings that can be selected by a single switch. The response and the consistency of the boost can be adjusted by using the GAIN, START BOOST setting. A built in warning feature will alert the driver when the boost exceeds the set boost pressure with an alarm and a message in the display. When the warning feature is activated, the LIMITER feature can lower the boost to a safe pressure. PEAK boost feature will allow the user to check the highest boost recorded.
$320
CLICK HERE TO ORDER
Old Oct 22, 2004 | 08:24 AM
prostreetonline
Dec 9, 2006 04:12 PM
silverb18
Sep 22, 2004 02:37 PM
prostreetonline
Aug 28, 2004 05:30 PM
