Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Nitrous on 404's
Old Aug 26, 2004 | 10:24 AM
hybrid_vtec's Avatar
Default Nitrous on 404's
what do you guys think about using N2O on a set Crower 404(nonvtec) w/ 11.1:1 compression! Not a good idea?
Old Aug 26, 2004 | 10:29 AM
Default Re: Nitrous on 404's (hybrid_vtec)
I am currently selling my N2O kit b/c I dont think it is safe, b/c of the overlap; but someone told they did it and ran fine! Just thought I'd ask before selling my nitrous kit!
Old Aug 27, 2004 | 05:43 AM
Bump!
Yes I know this is a pretty stupid queston
Old Aug 27, 2004 | 05:48 AM
StyleTEG's Avatar
Why would overlap cause it to be unsafe?
More of the nitrious is going to be scavanged out of the cyinders, but its not going to cause any damage.
Old Aug 27, 2004 | 06:41 AM
Greenery18's Avatar
Default Re: Nitrous on 404's (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Why would overlap cause it to be unsafe?
More of the nitrious is going to be scavanged out of the cyinders, but its not going to cause any damage.</TD></TR></TABLE>
This is true, but this could cause a lean or rich condition. I guess if your cams are tuned on nitrous, you should have no worries. They say the 403's are good for nitrous, so the 404's can't be all that bad...
Old Aug 27, 2004 | 06:45 AM
StyleTEG's Avatar
Default Re: Nitrous on 404's (Greenery18)
Why would less nitrious cause a lean condition?
If its a wet shot, or direct port, the correct amount of fuel should be injected. If the nitrious/fuel gets scavanged, it should remain in a safe range. Its no different than running N2O on an ITR motor (which unfortunetly lots of people do)
Old Aug 27, 2004 | 09:20 AM
I have a wet kit but Im afraid of spray it on the 404's and B16 Pistons! Maybe you guys are right and I shouldnt worry but I dont know!
Old Aug 27, 2004 | 09:27 AM
StyleTEG's Avatar
I would be more woried about the B16 slugs than the 404s
Old Aug 27, 2004 | 09:57 AM
why so, b/c they are factory pistons and the possiblity of running lean
Old Aug 27, 2004 | 10:06 AM
I just always heard if you are spraying that if you have to much overlap then it isnt good for the engine and it wont perform as well as it should with a cam with less overlap!
Old Aug 27, 2004 | 01:05 PM
StyleTEG's Avatar
It won't perform as well, yes, because you lose some of the nitrious. But its not bad for the engine. If anything cylinder pressure will be less, and it would be better for the engine.
B16 I would worry about because of the very high cylinder pressures with that high compression, and the chance of pre-ignition/detonation.
Old Aug 27, 2004 | 01:15 PM
So stay away from it since I have B16 Pistons in my LS
Old Aug 27, 2004 | 01:19 PM
JCushing's Avatar
sinice you have 404's im just going to assume you have cam gears so i would say if your worried then just dial the overlap out
StyleTEG's Avatar
As long as you have enough fuel you will be ok, just keep in mind that you will be at 10.8:1 CR which is going to be a slightly higher risk. If you don't detonate, you should be set.
Old Aug 27, 2004 | 01:35 PM
Fuel shouldnt be problem b/c my FPR will not go below 50psi, I need a new one! Anyway Im not worried about it b/c someone just bought my wet kit so I dont even need to think about spraying anymore!
Old Aug 28, 2004 | 05:48 PM
AsianMullet's Avatar
more fuel. wouldnt the overlap cause a problem though? im assuming you can change cam timing to make up for that overlap? Im not running 404s but this is what im assuming.
Old Aug 28, 2004 | 09:52 PM
StyleTEG's Avatar
Default Re: Nitrous on 404's (EKchump)
Yes you can dial out overlap. Why would overlap cause a problem?
Its no more overlap than ITR cams.
Old Aug 30, 2004 | 05:28 AM
Yeah but I went ahead and sold the kit though. I just dont want to deal with it anymore, b/c you cant use on the road coure or at autocross events anyway!
leroyb
Jul 20, 2007 09:44 PM
sileighty_911
Jan 7, 2007 02:33 PM
0618turbocivic
Jul 25, 2006 08:38 AM
ITRIK
Aug 18, 2005 07:26 AM
vteccrx909
Mar 20, 2004 03:02 AM
