Headlight brightness problem
its weird, ever since i got the car tuned on my hondata the headlights get brighter as i up the RPM and if i push the clutch in and rev, they get a whole lot brighter. any idea what it could be?
is there anyway i could have caused this with a modification? or will the warrenty cover it no problem....i have a mild set up (see below) but is it enough for honda/acura to give me **** if it does go?
Just make sure your caR appears to look stock, or as close as possible so they have less to bitch at.
Spark plugs have nothing to do with your alt going bad.
Good luck
Let us know what the outcome is
Good luck
it has nothing to do with your alternator. it is the actual hondata. do you have the s200? it has something to do with the alternate power. it is normal. call up hondata and ask them about it. PM "Mase" and he can tell you how to fix it. you have to cut a wire on your OBD conversion harness.
