Headlight brightness problem
Old Aug 26, 2004 | 12:47 AM
TypeRPaul's Avatar
Default Headlight brightness problem
its weird, ever since i got the car tuned on my hondata the headlights get brighter as i up the RPM and if i push the clutch in and rev, they get a whole lot brighter. any idea what it could be?
Old Aug 26, 2004 | 03:24 AM
Bbasso's Avatar
Default Re: Headlight brightness problem (TypeRPaul)
Alternator, thats it.
Old Aug 26, 2004 | 08:47 AM
TypeRPaul's Avatar
great so my alternator is on its way out?
Old Aug 26, 2004 | 08:50 AM
Bbasso's Avatar
Default Re: (TypeRPaul)
seems like it. Be careful that it does not surge and ***** up your wiring or pop the fuses.
Old Aug 26, 2004 | 08:54 AM
TypeRPaul's Avatar
is there anyway i could have caused this with a modification? or will the warrenty cover it no problem....i have a mild set up (see below) but is it enough for honda/acura to give me **** if it does go?
Old Aug 26, 2004 | 08:56 AM
Bbasso's Avatar
Seems like you should be able to get it covered under warrenty But don't let them see the ECU... they might try to blame it on that
Old Aug 26, 2004 | 09:00 AM
TypeRPaul's Avatar
should i swap in my stock ecu? also could it be related in anyway to my spark plugs no being gapped right or something?
Old Aug 26, 2004 | 03:23 PM
Bbasso's Avatar
Just make sure your caR appears to look stock, or as close as possible so they have less to bitch at.
Spark plugs have nothing to do with your alt going bad.
Good luck
Let us know what the outcome is
Old Aug 26, 2004 | 06:17 PM
TurblowR's Avatar
Default Re: (Bbasso)
it has nothing to do with your alternator. it is the actual hondata. do you have the s200? it has something to do with the alternate power. it is normal. call up hondata and ask them about it. PM "Mase" and he can tell you how to fix it. you have to cut a wire on your OBD conversion harness.
moEp3
Aug 29, 2010 06:22 PM
mikej94civex
13
Dec 9, 2009 09:23 AM
97elitehonda
Jun 27, 2007 02:10 PM
Mase
Aug 13, 2002 07:53 PM
