A/C making strange noise, help pls.
Old Aug 25, 2004 | 07:45 PM
98itr0448's Avatar
Default A/C making strange noise, help pls.
I rarely use my a/c in my R, but recenly I turned it on for a while on the interstate. I pulled up to a drive-through and heard an intermittent clicking noise coming from the engine bay. After I got my aRby's I pulled off to a parking spot and opened the hood. It sounded like a bearing rubbing or something. The only time I've heard a similar noise was in my 300zx days before my power steering pump bearing blew out= a mess. Anyway, I turned it on again today and immediately noticed the same noise. It doesn't happen when the air is on, only when a/c in engaged. I was thinking my compressor may be going bad, although it blows cold. Any idea's? Thanks
Old Aug 25, 2004 | 07:59 PM
Kicker773's Avatar
Default Re: A/C making strange noise, help pls. (98Itr-0448)
check your ac lines.. could be a leak..
Old Aug 26, 2004 | 05:16 AM
Petah's Avatar
Are you sure the intermitted "click" is not your compressor clutch engaging?
Old Aug 26, 2004 | 06:13 AM
Chris F's Avatar
Default Re: A/C making strange noise, help pls. (Petah)
Any chance it's the A/C fan by the radiator, not the compressor itself?
-Chris
Old Aug 26, 2004 | 06:48 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">I rarely use my a/c in my R, but recenly I turned it on for a while on the interstate. I pulled up to a drive-through and heard an intermittent clicking noise coming from the engine bay. After I got my aRby's I pulled off to a parking spot and opened the hood. It sounded like a bearing rubbing or something. The only time I've heard a similar noise was in my 300zx days before my power steering pump bearing blew out= a mess. Anyway, I turned it on again today and immediately noticed the same noise. It doesn't happen when the air is on, only when a/c in engaged. I was thinking my compressor may be going bad, although it blows cold. Any idea's? Thanks</TD></TR></TABLE>
Its due to the fact you do not use the a/c often. By occasionally using the a/c keeps the system lubricated. You may also want to check for belt tensioner and perhaps a belt replacement.
Old Aug 26, 2004 | 07:09 AM
Kamil's Avatar
Default Re: A/C making strange noise, help pls. (MUTANT X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUTANT X &raquo;</TD></TR><TR><TD CLASS="quote"> You may also want to check for belt tensioner and perhaps a belt replacement. </TD></TR></TABLE>
I agree, most likely the tension on the A/C belt.
Old Aug 26, 2004 | 07:18 AM
KOALA YUMMIES's Avatar
Default Re: A/C making strange noise, help pls. (Kamil)
I have a similar sound also only when I turn the A/C on. Sounds like a repetative clicking/chattering. I was thinking it was the belt as well.
Hernst
Honda CR-V & Element
Sep 22, 2015 02:22 PM
Tank_EM2
Honda Civic (2001 - 2005)
Apr 2, 2015 09:00 AM
ShadyBAB
Jun 16, 2006 10:59 AM
9civic5
Aug 24, 2005 09:37 PM
mattL
Jul 19, 2002 06:23 AM
