Vafc hack car idles very high! help!! pictures too.
Old Aug 25, 2004 | 12:38 PM
silverintegra83's Avatar
Default Vafc hack car idles very high! help!! pictures too.
car was tuned with the hack and bypass valves! idiot tuner. so i took the bypass valve off and hooked it up stock ( so i think) need help on that too.now there is 2 cylinoids(i don't know what they are) and only one is hooked up. should both be hooked up? well the setting i did at 1st was -35 low and -36 high across. for both narrow and wide. idles very high close to 2k rpm. well i saw someone elses post and did it this way.
1-4k= -40%
4.5k= -38%
5k= -36%
5.5-7k= -35%
idles a lil lower but still very high 1500rpm. now i am not sure i hooked up the map sensor correctly. so any help would be appreciated. i took sum pics. to make a good picture for u guys. oh and this is my setup.
b16a1
t3/t4 turbo
vafc
dsm 450cc
tial 35mm wastegate
no fmu
and here is what my vafc reads with both the setup at idle.
Old Aug 25, 2004 | 01:39 PM
Oyvind Ryeng's Avatar
Are you absolutely, 100% sure that there is no vacuum leak?
Old Aug 25, 2004 | 02:01 PM
Default Re: (Oyvind Ryeng)
well not sure. but vacuum at idle is 15-20.
Old Aug 25, 2004 | 04:07 PM
Default Re: (silverintegra83)
PLEASE HELP! i turned the idle control all the way down and it juz dropped to 1400 rpm. any other ideas? i think i hooked up the lines wrong.
Old Aug 25, 2004 | 05:56 PM
update one of my injectors are hissing! could this be the problem?
Old Aug 25, 2004 | 06:01 PM
ILLICON3000's Avatar
consider your self fortunate my idle skips and I'm lucky if it will idle more than 700 on any given day. I think I've got misfiring too going on
Old Aug 25, 2004 | 08:19 PM
EJ1 wilcox's Avatar
Default Re: (ILLICON3000)
Does your idle hold steady? Or does it move around more than normal?
Also, how many psi are you running?
Old Aug 25, 2004 | 08:23 PM
quik sol's Avatar
My car idles at 1500 on a cold start and then after about 1-2 minutes drops down to 750 and holds.
Old Aug 25, 2004 | 11:30 PM
Default Re: (quik sol)
holds steady at 1400. this is with the car warm, not cold. 9psi.
Old Aug 25, 2004 | 11:34 PM
99blackcivicSi's Avatar
my car ran good with the hack i had it tuned a little rich just from the little ghetto tune i threw in it, but i used a vacuum manifold and i had no vacuum leaks, check for leaks, you can find them in the most un useual places, also put zipties on all of your vacuum lines because they can and will pop off
Old Aug 26, 2004 | 04:20 AM
USDM 4G VTEC's Avatar
Default Re: (99blackcivicSi)
judgeing by the pics this looks like a teg
i would try to fit a D16Z6 TB into that B16, that way u get the TB mounted MAP sensor
anwyays i got a turbo D @ 9 psi and runs great on the VAFC Hack
i got
-37% from 1k-2.5k rpms
-36% from 3-3.5k rpms
-35% from 4k-5k rpms
-33% from 5.5-8k rpms
Old Aug 26, 2004 | 06:09 PM
Default Re: (USDM 4G VTEC)
Dammit_Dan_954
May 5, 2004 10:33 PM
lsvtec101
Apr 4, 2003 04:05 AM
1.8T_EG
Oct 25, 2002 09:31 AM
CalvitoSol
Jun 17, 2002 09:13 PM
