Is a turbo from a gas car and diesel car be the same?
the turbos are essentially the same in design and function, however the turbine housings on diesel turbos are realatively small compared to a gasoline engine.
so would there be any unforseen problems running diesel turbo on a honda engine? i've been told they spool really quick good for mid range but bad for hi end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross »</TD></TR><TR><TD CLASS="quote">the turbos are essentially the same in design and function, however the turbine housings on diesel turbos are realatively small compared to a gasoline engine.</TD></TR></TABLE>
You got it just the opposite. Most diesels use turbos with T4 exhaust sides and housings with A/R's in the high 80's and 90's (ie: .82, .86, .92, etc) which are too big for most street hondas that typically use a T3 exhaust wheel and a .63 A/R housing.
TheIntegraGuy
Aug 9, 2005 11:00 AM
