WHAT HAS HONDA DONE TO MY CAR?!!?
Old Aug 24, 2004 | 05:57 PM
MtnCRX's Avatar
Default WHAT HAS HONDA DONE TO MY CAR?!!?
so i take my 89 crx si to honda because of a serious braking problem (fronts dont work.) They tell me my brake diaphragm has busted and my brake booster etc is shot. they also change my timing belt because the fluid has leaked onto and ruined it. . So i come back the next day and drive the car away. Only to discover IT DOESNT ACCELERATE. I floor it in 1st gear and it literally takes about 5 seconds to get to second. After second, theres no use in shifting because i cant get a far enough straightaway to get it past 5 or 6k rpms. If i shift before then, it begins to bog down. here are my mods
JR supercharger on d16 running 10 pds of boost w/ boost guage
JR fuel pump
JR fuel pressure regulator (at 34 pds) w/ pressure guage
DC headers, powercore race cat, cust. 2.5 inch exhaust
MSD Boost timing master w/ air/fuel guage.
The supercharger is working because the boost guage tells me its boosting and i can hear it. The FPR is still at 34 pds. ANOTHER THING is, the car is a LOT louder than it used to be (and i mean A LOT.)
Could this be a timing issue? if so, would it really make THIS much of an impact? i mean, i cant even make it up hills without flooring it in second now. some vacuum issue with my pedal or something?!? please help!!
Old Aug 24, 2004 | 05:58 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (MtnCRX)
weird. check your timing first.
Old Aug 24, 2004 | 06:01 PM
SoEvoL's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (boostincoupe)
sounds like horrible timing, for a boosted car, it shouldnt be that sluggish. then again i have my timing at -20 and i still drive fine, slow as hell but it drives fine.
Old Aug 24, 2004 | 06:03 PM
ek_99_SiR's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (JDMCrx89)
maybe the honda mechanics drove it a lil too hard?
beepy's Avatar
Sounds like bad valve timing. Since they replaced the timing belt I would say they screwed it up. The increase in noise level might be valves lightly slapping the pistons.
Old Aug 24, 2004 | 06:04 PM
night's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (1.6i-16zc)
i think u been had.
break fluid leaking onto the tbelt O_o
Old Aug 24, 2004 | 06:11 PM
MtnCRX's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (night)
he said the belt was not weatherproof... it feels like my engine is near death.. wtf wtf wtf
Old Aug 24, 2004 | 06:42 PM
thumbtack's Avatar
Take it back to your dealer?
Old Aug 24, 2004 | 07:01 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by night &raquo;</TD></TR><TR><TD CLASS="quote">i think u been had.
break fluid leaking onto the tbelt O_o</TD></TR></TABLE>
Sounds like a mighty interesting leak, if it's true... would require pictures for me to believe it.
Tards and Timing belts don't mix.
Old Aug 24, 2004 | 07:13 PM
slooogsr's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Tards and Timing belts don't mix.</TD></TR></TABLE>
Old Aug 24, 2004 | 07:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (slooogsr)
timing has to be off....
Old Aug 24, 2004 | 07:20 PM
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (Hella_JDM)
you get that piece of **** running yet?
Old Aug 24, 2004 | 08:01 PM
stizzit's Avatar
pull of the belt cover and look at the gears, they're probably off by a couple teeth possibly combined with some nasty ignition timing. don't freak out until you check ignition and mechanical timing!
Old Aug 24, 2004 | 08:30 PM
neon_ice's Avatar
ha, screw doin it urself, they should have adjusted it back to where it was, THEY are the mechanics your paying, you shouldnt have to fix what they changed, especialy if you payed them
Old Aug 24, 2004 | 09:36 PM
DRIVENRacing's Avatar
why have honda work on your ****?
Old Aug 24, 2004 | 11:15 PM
leadfoot78's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (TurboHybridEG6)
I say they they took your car for a spin and blew something up. I say this because I just can't imagine how some one could **** up a belt change on a SOHC, its just two pulleys one on bottom and one on top, how hard could it be?? Also, word of advice, do not touch any thing around the car, take is back to the dealer as soon as possible and tell them what happened in a nice way, if they don't fix what was wrong with the car make it a legal issue.
Old Aug 25, 2004 | 10:41 PM
MtnCRX's Avatar
The power problem is fixed anyway. Timing was way off because the belt had slipped. Thanks to those who gave me great advice.
Old Aug 25, 2004 | 10:49 PM
honda9369's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like bad valve timing. Since they replaced the timing belt I would say they screwed it up. The increase in noise level might be valves lightly slapping the pistons.</TD></TR></TABLE>
cha-ching
Old Aug 25, 2004 | 10:50 PM
a1320honda's Avatar
was it a problem of them not getting the tensioner tight enough. for a honda dealership to **** something up that bad is pretty rare. did they take care of it or what was the deal. also are you sure you didnt incure any internal damage?
Old Aug 26, 2004 | 02:26 PM
MtnCRX's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (a1320honda)
they said they installed the belt and put the timing to stock specifications. When they got the car back after i complained, they used the timing light right away and saw it was way off. They werent sure if a mechanic had done it wrong or the belt had just slipped but this was the first time (they say) they had the problem. from what i understood the spark was occuring after the pistons were on their way down. *yikes*
Old Aug 26, 2004 | 02:40 PM
a1320honda's Avatar
ya thats bad, but all is good now?
Old Aug 26, 2004 | 02:43 PM
mattssi's Avatar
A brand new belt shouln't slip. And if it did, that means that they didn't put it on right. either way you slice it, they did it wrong. If it was running like crap, I would have never left the dealership. But it is fixed. so oh well. Good thing that it didn't cause any other damage like bent valves, you would of had to pull teeth to get them to replace them. They couldn't even admit they made a mistake? My dealership here is nice. they cop to everything. and fix it right away!
Old Aug 26, 2004 | 02:59 PM
honda9369's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (mattssi)
dude whether or not they no what there doing. i will never go to a honda dealer. there prices for repair are insane. break out the repair manual next time. between that and h-t you should be able to repair anything yourself
Old Aug 27, 2004 | 01:09 AM
MtnCRX's Avatar
Default Re: WHAT HAS HONDA DONE TO MY CAR?!!? (honda9369)
yeah now i know!
... and knowing is half the battle!
rfelix89
Sep 20, 2012 11:43 PM
MtnCRX
14
Aug 25, 2004 11:14 PM
MtnCRX
Aug 25, 2004 10:41 PM
variablevalve
Jun 8, 2004 04:36 PM
GSRwBOOST
Jul 11, 2001 10:33 AM
