b16 swap into 92 si hatch questions (already searched)
Old Aug 24, 2004 | 05:49 PM
PuiPui's Avatar
Default b16 swap into 92 si hatch questions (already searched)
please don't flame, i've been searching for 2 hours already and are getting tired. there are a ton of posts to go through in that thing.
heres the situation, i bought a crashed (tboned) 2000 si (sir in canada), the motor works and axles are okay. However, i'm taking it to my friends shop to get the swap done, what EXACTLY do i need to tell them to take out of the car (because the rest of the car doesn't exactly belong to me, i have 2 days to take everything i need out). I know i need the engine assemby (tranny dizzy starter etcetc), shift linkage and the axles. can i use the ECU? or can i use mine from a 92 si hatch and get it rechipped with b16a basemaps? I know i need 3 of the 5 3rd gen integra engine mounts. Can i use the radiator, engine harness? I read here on h-t that i can use the engine harness from a ODB-II integra and that should plug right into mine at the shock tower?
again i'm really sorry for bugging and i wish i found everything i needed in the search, i am completely new at this and so is my friends dad that's willing to try this with me. Any HOW TO's or COMPLETE PARTS LISTS would be great help, also anyone willing to let me annoy them on PM please drop me a message, because i am really excited to do this, i just want things to go smoothly, because i read so many posts of HT members doing this in their garage i want to do the same. Thanks!
to be really clear again, a 2000 si (b16a2) into a 1992 civic si (d16z6)
Old Aug 24, 2004 | 06:21 PM
JDMisGOOD's Avatar
Default Re: b16 swap into 92 si hatch questions (PuiPui)
just strip every useable piece off of the SiR
Old Aug 24, 2004 | 06:26 PM
2lua's Avatar
use your 92 stock harness and ecu. take everything out of the 2k si if you could.
Old Aug 24, 2004 | 06:50 PM
sit220's Avatar
Default Re: b16 swap into 92 si hatch questions (2lua)
dont forgrt about the rear disk brakes
use the 2000 si ecu and convert to obd2
dont need motor mounts
Old Aug 24, 2004 | 08:09 PM
PuiPui's Avatar
Default Re: b16 swap into 92 si hatch questions (sit220)
don't need motor mounts? can anyone else verify this i was so sure about it, and i can use my ecu? i need the b16a2 basemap then right?. i already have rear disc brakes from the si, are the sir ones better? thanks
Old Aug 24, 2004 | 08:25 PM
pennies_hatchie's Avatar
what you need from the si
1. motor/trans/header/axles/mounts
making it work
1. gsr rear L bracket, si tranny (top/bottom), gsr side mount, and si a/c mount (that makes 5)
2. gsr/del sol vtec/your oem 92 si harness will work on the b16a2
3. get your p28 rechipped or buy a p30 (jdm obd1 b16a sir2 ecu )
the rest is plug and play.
about the rear disc brakes on the sir, just take it off and sell it since you have that on your si (your oem brakes are smaller though, so itll make a nice upgrade)
Old Aug 25, 2004 | 04:11 PM
PuiPui's Avatar
Default Re: b16 swap into 92 si hatch questions (pennies_hatchie)
thank you for the responses, just wanted to give you an update, i paid 2250cdn for everything i need for the swap, i believe this is pretty cheap, and i'm majorly excited! thanks again!
Old Aug 25, 2004 | 05:38 PM
sit220's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">
i never seen a 92 si oem with rear disk brakes
Old Aug 26, 2004 | 11:11 AM
3lue_by_u's Avatar
mine have oem disks in the rear.
Old Aug 26, 2004 | 11:19 AM
B.'s Avatar
B.
400 HP Club
i did the same swap as you and you dont want to use the obd2 ecu, i mean get it if you can, but I would convert it to obd1 and a chipped p28, way better HP results... trust me. oh ya get the sir shift linkage too.
Old Aug 26, 2004 | 11:26 AM
JDMlyfestyle's Avatar
Ya do not convert to OBDII. Lemme tell ya. those things are so strict they will throw a CEL if a car passes u to fast...lol a little sacastic. But the OBD I p28 chipped with the Skunk program should work very well with u on here.
pliskin679
May 5, 2007 10:20 AM
boostd ls
Apr 12, 2007 02:02 AM
1SlowSi
25
Mar 9, 2004 08:28 PM
Civichatch972
Oct 6, 2002 01:42 PM
