VTEC OR NO VTEC... how can I tell if itīs working?
Old Dec 3, 2001 | 08:47 PM
GReddyEXcoupe's Avatar
Default VTEC OR NO VTEC... how can I tell if itīs working?
Someone told me something like "your vtec wont work if you use the black box on the GReddy turbo kit
My car is a 95 OBD1 d16z6
is this true?
how can I know this?
wich wire on the solenoid can I tamper to know?
Old Dec 4, 2001 | 03:30 AM
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (GReddyEXcoupe)
anyone?
hello?...
Old Dec 4, 2001 | 05:34 AM
charjacq's Avatar
New User
If you don't notice anything wrong when you get in the high rpm range, you know it's working. If you start losing power above 5k, then you know it's not working. If you really want to test it, I think there should only be one wire going to the solenoid, cut it and notice the difference.
Old Dec 4, 2001 | 06:49 AM
how can I build a temporary VTEC light?
wich wires???
to the ecu or in the solenoid?
heeeeelp again!
Old Dec 4, 2001 | 07:51 AM
KEVlN's Avatar
New User
yeah I would like to know how to build a vtec light as well. Let us know how.
Old Dec 4, 2001 | 08:25 AM
Sohc Driver's Avatar
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (Civic95)
Umm..i dont' know about u guyz...but once i got a short ram intake ages ago on my SOHC vtec..i could hear vtec engage.....and also feel the difference..compared to my friend when he fucked up his wiring...lol...and it cut off his vtec...but if u can't hear it..then..i dunno what to tell you...its a very distinguishable sound....
My two cents,
Khoi
P.S..its nothing like a DOHC vtec...but u can still hear SOHC Vtec engage...
Old Dec 4, 2001 | 01:58 PM
Civic Hatch Boy's Avatar
New User
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (Sohc Driver)
take ur vtec wire, and jump it to a LED. so let the LED stand as a bypass to ur vtec wire. so when current flows, the LEd should light when vtec hits.
Old Dec 5, 2001 | 07:19 AM
and the other wire to ground? thats it?
Old Dec 5, 2001 | 11:33 AM
KEVlN's Avatar
New User
Where is my vtec wire? I am still learning. Thanks for your help.
Old Dec 5, 2001 | 11:41 AM
liam821's Avatar
25 Year Member
i dont think thats true...vtec should work fine. You should beable to feel/hear vtec kick in at 4800 rpms.
liam
Old Dec 5, 2001 | 12:58 PM
neumonik's Avatar
Try here....
http://www.hazone.com/howto/vlight.htm
Old Dec 5, 2001 | 01:39 PM
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (neumonik)
I cant hear the vtec... the turbo is really loud
Old Dec 8, 2001 | 07:45 PM
Thanxs
Iīll make one with a blue led, kinda playstation 2
Old Dec 8, 2001 | 08:03 PM
spyder's Avatar
New User
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (liam821)
liam
It is at 5500, not 4800 (unless the black box reprograms it and I don't know about it). Put it in 2nd and take it slowly to 4000, then floor it. As it passes 5500RPM you should hear a change in the sound. When that sound changes (in higher RPM band), that is when VTEC activates.
Old Dec 8, 2001 | 09:13 PM
Mista Bone's Avatar
D Tranny Guru
red or green 12v LED from rat shack. I used a Bosch relay in the wire to the VTEC solenoid. I mount the relay and LED just below the hazard switch. That way I can here the relay and see the switch.
BTW VTEC on SOHC can switch over between 4800 rpm and 5300 rpm on a REAL tach. Add 200 rpm higher if you are reading a factory tach.
WOT VTEC switchover is at 4800 rpm on REAL tach, 5000 rpm on a stock tach.
Old Dec 8, 2001 | 09:39 PM
Phantom's Avatar
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (Mista Bone)
not all stock tach's are equal either...
i had a stock 97 ex, my rev limiter in neutral for my stock tach was 7400, in my friend's 96 ex with my stock ecu, his rev limiter was 7000 even, im not trying to prove you wrong, just point out my experience - neither instrument cluster was ever touched, so the calibration should not have been affected
vtec SHOULD be 4800 at wot, no doubt there.
Old Dec 9, 2001 | 10:59 AM
spyder's Avatar
New User
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (Phantom)
Crossover point on my stock '96 ex on stock tach at WOT is 5500, which would be *roughly* 5300 on a real tach, but that's still nowhere near 4800.
Old Dec 9, 2001 | 01:45 PM
TurboLsVtec's Avatar
Well In A SOHC... Vtec barely kicks in.....(well actually, you can barely feel Vtec) If you open ur down pipe. You can actually here vtec kick in. WHat I did when my lsvtec's vtec did not kick in, I installed a V-afc vtec controller.. and after that....It started to work.. Wehn you start the car (cold) vtec will not owrk because it needs oil to run up to the solenoid. Vtec operates when the car is warm.
Old Dec 9, 2001 | 05:07 PM
SjCiViCHB's Avatar
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (TurboLsVtec)
is it true vtec doesnt work well with turbos? ive been told by a couple turob guys that most of time when the cars are turboed, vtec is turned off cause vtec and the high boost dont fuctin well together in the high rpms.
Old Dec 9, 2001 | 05:37 PM
Type-ARR's Avatar
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (SjCiViCHB)
Old Dec 9, 2001 | 08:06 PM
SjCiViCHB's Avatar
Default Re: VTEC OR NO VTEC... how can I tell if itīs working? (ITR-481)
thanks...my head hurts now...
Old Dec 9, 2001 | 08:09 PM
spyder's Avatar
New User
Well, there is at least some truth to this. One of the objects of VTEC is to open the valves more at high RPM to allow better flow into (and out of) the cylinder. The purpose of a turbo is to literally cram air down the engine's throat, forcing it into the cylinder in greater quantities. If you have the exhaust valve open too much (VTEC) then there is the possibility of valve blow-by occuring. This is where the air/fuel mixture coming in the intake valve comes it at such speed and quantity, that it starts escaping out the exhaust valve before it closes. This causes a loss in power.
note to others: yes I know blow-by is most likely the result of excessive valve overlap, but greater overlap automatically occurs when the valve lift is greater (unless specifically tuned out which VTEC does not do).
swizz977
10
May 25, 2011 08:15 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
Hatch It
Aug 12, 2004 08:34 AM
oscar_lopez03
Jul 1, 2004 07:14 PM
Wave
Aug 1, 2003 06:04 PM
