VTEC OR NO VTEC... how can I tell if itīs working?
Someone told me something like "your vtec wont work if you use the black box on the GReddy turbo kit
My car is a 95 OBD1 d16z6
is this true?
how can I know this?
wich wire on the solenoid can I tamper to know?
is this true?
Re: VTEC OR NO VTEC... how can I tell if itīs working? (GReddyEXcoupe)
If you don't notice anything wrong when you get in the high rpm range, you know it's working. If you start losing power above 5k, then you know it's not working. If you really want to test it, I think there should only be one wire going to the solenoid, cut it and notice the difference.
Re: VTEC OR NO VTEC... how can I tell if itīs working? (Civic95)
Umm..i dont' know about u guyz...but once i got a short ram intake ages ago on my SOHC vtec..i could hear vtec engage.....and also feel the difference..compared to my friend when he fucked up his wiring...lol...and it cut off his vtec...but if u can't hear it..then..i dunno what to tell you...its a very distinguishable sound....
My two cents,
Khoi
P.S..its nothing like a DOHC vtec...but u can still hear SOHC Vtec engage...
My two cents,
Khoi
New User
Re: VTEC OR NO VTEC... how can I tell if itīs working? (Sohc Driver)
take ur vtec wire, and jump it to a LED. so let the LED stand as a bypass to ur vtec wire. so when current flows, the LEd should light when vtec hits.
i dont think thats true...vtec should work fine. You should beable to feel/hear vtec kick in at 4800 rpms.
liam
liam
Try here....
http://www.hazone.com/howto/vlight.htm
Re: VTEC OR NO VTEC... how can I tell if itīs working? (liam821)
liam
liam
D Tranny Guru
red or green 12v LED from rat shack. I used a Bosch relay in the wire to the VTEC solenoid. I mount the relay and LED just below the hazard switch. That way I can here the relay and see the switch.
BTW VTEC on SOHC can switch over between 4800 rpm and 5300 rpm on a REAL tach. Add 200 rpm higher if you are reading a factory tach.
WOT VTEC switchover is at 4800 rpm on REAL tach, 5000 rpm on a stock tach.
Re: VTEC OR NO VTEC... how can I tell if itīs working? (Mista Bone)
not all stock tach's are equal either...
i had a stock 97 ex, my rev limiter in neutral for my stock tach was 7400, in my friend's 96 ex with my stock ecu, his rev limiter was 7000 even, im not trying to prove you wrong, just point out my experience - neither instrument cluster was ever touched, so the calibration should not have been affected
vtec SHOULD be 4800 at wot, no doubt there.
Re: VTEC OR NO VTEC... how can I tell if itīs working? (Phantom)
Crossover point on my stock '96 ex on stock tach at WOT is 5500, which would be *roughly* 5300 on a real tach, but that's still nowhere near 4800.
Well In A SOHC... Vtec barely kicks in.....(well actually, you can barely feel Vtec) If you open ur down pipe. You can actually here vtec kick in. WHat I did when my lsvtec's vtec did not kick in, I installed a V-afc vtec controller.. and after that....It started to work.. Wehn you start the car (cold) vtec will not owrk because it needs oil to run up to the solenoid. Vtec operates when the car is warm.
Re: VTEC OR NO VTEC... how can I tell if itīs working? (TurboLsVtec)
is it true vtec doesnt work well with turbos? ive been told by a couple turob guys that most of time when the cars are turboed, vtec is turned off cause vtec and the high boost dont fuctin well together in the high rpms.
Re: VTEC OR NO VTEC... how can I tell if itīs working? (SjCiViCHB)
note to others: yes I know blow-by is most likely the result of excessive valve overlap, but greater overlap automatically occurs when the valve lift is greater (unless specifically tuned out which VTEC does not do).
AnAccordIsForever
06-03-2008 03:27 PM
Hatch It
08-12-2004 08:34 AM
