Tranny Click.......
Old Aug 23, 2004 | 10:53 PM
H22SiRaccord's Avatar
Default Tranny Click.......
Aight so i have been having trouble with my tranny. The problem being everytime i go into drive and start to go i hear a clicking noise from my axles....The clicking comes and goes....anybody got any input on this.
Old Aug 23, 2004 | 10:57 PM
freedom101's Avatar
Default Re: Tranny Click....... (H22SiRaccord)
Can you explain the noise to me more? Like when does it usually make the sound? How long? If you can answer that I think i may be able to help.
Old Aug 23, 2004 | 11:03 PM
Just when i first step on the gas....like right as it engages into Drive it goes click....also does it in reverse. I will put in reverse and barley get on the gas and it goes click....it is a quite little click....wish i could explain it better..
Old Aug 23, 2004 | 11:08 PM
freedom101's Avatar
Default Re: (H22SiRaccord)
Does it sound like a turbo/whine at all? If so it may be an input/output bearing..I know i have to fix that on my dads car and im sure thats the problem for a turbo sound.
Old Aug 23, 2004 | 11:11 PM
freedom101's Avatar
Does the car shake at all? Maybe if you just sit still and shift then press on the gas lightly..Idk, its hard to say without hearing it....
nahh....it isnt a turbo sound....almost sounds like something breaking....guess i will get under there and check my CV joints and Boots tom.....
Old Aug 24, 2004 | 08:12 AM
93CivicDxer's Avatar
It might sound like the axles.....But I would check the motor mounts first. Have a friend look at the motor when you put it in drive or reverse. Hold the brake while doing this. If the motor moves alot check all the motor mounts and dont forget the rear motor mount. Its under the intake manifold.
good luck
Old Aug 24, 2004 | 02:00 PM
madd's Avatar
Default Re: Tranny Click....... (AcCoRdInGtO_91)
i have the same problem....if it were the axles i would figure that there would be more symptoms...especially in corners, etc... it is kind of annoying though...anyone?
Old Aug 24, 2004 | 07:49 PM
cmrvi1's Avatar
I've come across this problem many times before. Take off in drive, you hear a single click. Put it in reverse, as you accelerate....click. RIGHT??
Turns out to be that the axle nuts are incorrectly torqued.
To get rid of the noise, you'll have to loosen the axle nuts and then retighten them.
Old Aug 24, 2004 | 09:58 PM
Default Re: Tranny Click....... (cmrvi1)
U just hit it on the noise...i will check the torque on the bolts
Old Aug 25, 2004 | 08:31 AM
alotawatts's Avatar
I think the lug nut tightening is too optimistic of a fix although it could be that simple. Our Civic does the same thing some times and I suspect it's backlash in the transmission / half shafts.
Old Aug 25, 2004 | 10:32 AM
BlkChryKord's Avatar
Default Re: Tranny Click....... (alotawatts)
Mine does this as well (98 coupe) and I check the boots and suspension. Nothing was torn, worn, or broken. I'd say he ---^ has the best answer as to what the problem is.
Old Sep 3, 2004 | 09:21 AM
Hmmm......still thinkin what the problem could be but i do thank you all for your input.
Old Feb 1, 2007 | 09:30 AM
fbp cd5's Avatar
Bringing this back up, but I have the same issue on my 97 Accord as stated in the original post. When I shift out of park to drive or reverse there is a single click, when I get on the gas from a dead stop there will also be a single click, and occasionally when the transmission shifts from gear to gear there is a single click. Any other ideas aside from tightening the axle nut as stated. thanks!
Old Feb 5, 2007 | 11:02 AM
sony224422's Avatar
Default Re: (fbp cd5)
is it an auto?
Old Feb 5, 2007 | 03:42 PM
ramoneguru's Avatar
I had a similar problem. So we put the car on jacks and I had my friend shift from park to 4th, heard a click, then from 4th to reverse, heard a click. Turns out it was the rear motor mount and the front motor mount. The front one was completely separated from the rubber inside the mount. Had it replaced..........now it only clicks when I go in reverse ahahhaha (didn't do the rear one yet since its a bitch). Think I'll replace the side mounts too......might as well since they are right there anyways.
Old Feb 8, 2007 | 10:26 AM
fbp cd5's Avatar
Default Re: Tranny Click....... (ramoneguru)
Yes, it is an auto. I'll check my motor mounts this weekend. thanks for the info/help.
Old Feb 8, 2007 | 02:42 PM
YeuEmMaiMai's Avatar
Default Re: Tranny Click....... (fbp cd5)
year of accord? my 94 does that in the winter time because the fluid has not thinned out enough it can be just the shift fork engaging as well
Old Feb 8, 2007 | 02:59 PM
philadd's Avatar
Default Re: Tranny Click....... (YeuEmMaiMai)
Mine clicks a split second after I start accelerating, but only if I just put it into drive from neutral. If I wait a couple seconds before accelerating, no click. (And yes, the tranny engages before I put my foot on the gas.) It's always done this. It doesn't do it again until I take the car out of Drive.
If I reverse, then apply the brakes, there is an audible click from the brake pads shifting inside the caliper. This only happens the first time I brake while in reverse.
I consider both of these things normal. I only mention them as a possible cause of your clicking.
Old Feb 8, 2007 | 03:48 PM
02 accord's Avatar
Default Re: Tranny Click....... (philadd)
When I put my auto in drive, it goes into gear (car starts moving), and about 1/2 sec later, it clicks. If I get on the gas right after it goes into gear but before it clicks, the car starts moving, but then there's a jerk when it does click. Seems like it goes into gear but slips a little, and 1/2 sec later it locks in. Is this a feature of the tranny that prevents it from being neutral slammed?
Old Feb 8, 2007 | 04:21 PM
philadd's Avatar
Default Re: Tranny Click....... (02 accord)
I'm not sure... I've never felt a jerk when it clicks, no matter how hard I'm on the gas.
I've also never tried a neutral slam (nor will I), so I can't even say if it is or is not possible on 6th gens.
em2power
Honda Civic (2001 - 2005)
Jan 5, 2008 07:23 PM
SkIp_Civic_Ek6
Mar 19, 2007 12:06 AM
Cwhiteg6
May 30, 2006 03:25 PM
all stock
29
Mar 15, 2003 01:45 PM
