Engine stand bolts.
I've read that the transmission bolts will work with perfect length. Well i don't have any spare transmission bolts. I need to know the correct thread size and bolt length.
It appears that there are one hole on both sides that are larger? Look like 14mm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis »</TD></TR><TR><TD CLASS="quote">ok home depot's bolt supply sucks ***</TD></TR></TABLE>
i agree with that totally they have s hitty selection of metric bolts and the ones they ahve are too short anyway.
only one of the transmission bolts will be long enough to work
that's the one going through the starter to the tranny.
take that bolt with you to the hardware store and find a nut that will
screw onto that bolt. once you find a nut, look for another bolt
that will match up to that nut and is just as long as your tranny bolt.
the home depot in my area didn't have the right size, but ace hardware did.
it's a metric fine thread bolt, i can tell you that for sure
usually honda bolts have a pitch of 1.25, the hard part is always fiunding the right length not the right diameter...the big hardware stores suck they usually only carry at most a 60mm bolt which is about 2.38 inchs long
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">usually honda bolts have a pitch of 1.25, the hard part is always fiunding the right length not the right diameter...the big hardware stores suck they usually only carry at most a 60mm bolt which is about 2.38 inchs long</TD></TR></TABLE>hmm yea 2.38 inches is a few too short... i might try taking that one bolt out when I have time thanks for the help
explictness
12
Dec 26, 2005 05:14 PM
BLUE EH3
13
Jun 6, 2005 02:04 PM
