Can I adjust clutch tension??
Old Aug 23, 2004 | 03:14 PM
I8ayellowcrayon's Avatar
Default Can I adjust clutch tension??
I broke my clutch cable today on my lunch break . Just wanting to know if there is any way to adjust the tension of the clutch, because it is extremely stiff. I can't even pull the clutch arm up by hand... Its ridiculous... TIA.
Old Aug 23, 2004 | 03:15 PM
EL Vap133's Avatar
Default Re: Can I adjust clutch tension?? (I8ayellowcrayon)
Have you replaced the broken clutch cable yet?
Old Aug 23, 2004 | 03:20 PM
Just about to. Just thought I would do some research before I jumped into it.
If you're thinking of adjusting the cable, I know about that. I need to know if I can adjust the tension on the clutch/clutch arm itself.
Old Aug 23, 2004 | 03:31 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">I broke my clutch cable today on my lunch break . Just wanting to know if there is any way to adjust the tension of the clutch, because it is extremely stiff. I can't even pull the clutch arm up by hand... Its ridiculous... TIA.</TD></TR></TABLE>
Buy a weak street clutch and not a good performance clutch.
The springs and stuff on a good pressure plate make it difficult to actuate by hand.
Old Aug 23, 2004 | 03:38 PM
But should it be breaking the stinking cable?? Its a Clutch Masters stage 3 clutch, but still. I shouldn't be shredding clutch cables because of it.
Old Aug 23, 2004 | 04:09 PM
EL Vap133's Avatar
Before my clutch cable broke, it was stiffer than hell, once it broke I bought a new one from Acura and now my clutch pedal is easy.
Old Aug 23, 2004 | 04:40 PM
Well, I replaced it and its pretty loose now. I guess it was just kinked somewhere or something. Thanks for the help guys.
Old Aug 23, 2004 | 06:08 PM
92integra_gs's Avatar
note to self: clutch cable get stiff... i mean really stiff really stiff before breaking off
Old Aug 23, 2004 | 06:14 PM
what?
Old Aug 23, 2004 | 07:18 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (I8ayellowcrayon)
Before the cable snaps,it starts to "fray"..
individual strands start to snap as it becomes
weaker..The loose strands then tend to bind up the cable inside..
b16a27
Feb 5, 2005 08:48 PM
turbotime
Aug 9, 2004 07:33 AM
4DRmafia
Jun 10, 2004 06:58 AM
DroppedTegLS
Sep 28, 2002 01:51 PM
