ITR CAM vs CTR CAM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard »</TD></TR><TR><TD CLASS="quote">00-01 ITR's have basically that same cam as CTR.</TD></TR></TABLE>
Yup, the profiles are so similar from the pics and threads I have read that its useless to say they are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">How much would I gain from ITR to CTR on B18C5 with all the bolts on??
3hp? 4hp? 5hp??
There is only the very slightest difference on the intake side.
I don't think anyone's actually ever measured it on a dyno, but the dyno-proved difference would not be sufficient enough to warrant changing the cams if you already have '97-'98 USDM ITR cams.
Maybe 1-2 HP, with a perceived seat of the pants difference in responsiveness at some RPM. And you could only measure the difference on the same car...for some reason a stock '97 USDM ITR will dyno a couple of horses higher than a stock '00 USDM ITR, even though the '00 car will feel stronger and have slightly better acceleration.
3hp? 4hp? 5hp??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
I don't think anyone's actually ever measured it on a dyno, but the dyno-proved difference would not be sufficient enough to warrant changing the cams if you already have '97-'98 USDM ITR cams.</TD></TR></TABLE>
Trey has done this.
Trey has done this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
Trey has done this.</TD></TR></TABLE>
Do you remember what he found?
i would think it's in the 3-4hp area.. the reason honda did that was to conpensate for stricter emissions and ecu software in 00-01 than in 98.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">i would think it's in the 3-4hp area.. the reason honda did that was to conpensate for stricter emissions and ecu software in 00-01 than in 98.</TD></TR></TABLE>
LOL.... I guess they didn't forget the time they had dealers waiting for 100 ITR that were impounded at the dock for emissions violations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">Nothing?</TD></TR></TABLE>
Mr. commanda said that the switch in cams was done with a few other things, so it wasn't possible for a straight comparison. But from the sounds of it, it does sound like 3-4whp or less.
teamvirus
Aug 25, 2005 05:52 AM
