itr ctr cam question
Old Oct 16, 2003 | 01:55 PM
sdchump's Avatar
Default itr ctr cam question
what is the most aggressive cam setup using OEM parts? e.g. i heard that ppl like to have an ITR intake cam with a CTR exhaust cam, or is it the other way around. i forgot which combination it is. thanks for the help.
Old Oct 16, 2003 | 02:00 PM
P1mpSlap's Avatar
https://honda-tech.com/zerosearch
Old Oct 16, 2003 | 02:02 PM
sdchump's Avatar
Default Re: itr ctr cam question (sdchump)
i tried the search already
Old Oct 16, 2003 | 02:04 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdchump &raquo;</TD></TR><TR><TD CLASS="quote">i tried the search already</TD></TR></TABLE>
cool, but I'm sifting through 717 results for "ITR Cams" try again maybe you'll pick something extra up that you need to know.
Old Oct 16, 2003 | 10:25 PM
Cole D's Avatar
ctr is the most aggressive of the two the difference is small 3 degrees on the intake so its debatable the exhaust is the same hope this help
Chris
Old Oct 16, 2003 | 10:50 PM
sinfulDB1's Avatar
Default Re: itr ctr cam question (chriscoleman102)
i think CTR cams are the same as the 2000-2001 ITR cams
Old Oct 16, 2003 | 10:59 PM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chriscoleman102 &raquo;</TD></TR><TR><TD CLASS="quote">ctr is the most aggressive of the two the difference is small 3 degrees on the intake so its debatable the exhaust is the same hope this help
Chris</TD></TR></TABLE>
This is incorrect... partialy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikendc2 &raquo;</TD></TR><TR><TD CLASS="quote">i think CTR cams are the same as the 2000-2001 ITR cams</TD></TR></TABLE>
This is correct.
Here are the specs.
This information was taken from Sam Karp's great B-Series Cam Guide posted at ClubSi.
Following Cams Measured at 1mm of lift:
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
It should also be noted that I posted this same exact thing, in this same forum less than a week ago. In this thread Please search.
Old Oct 17, 2003 | 05:34 AM
patdemps's Avatar
Default Re: itr ctr cam question (Gabe_)
Grab some 00-01 ITR cams in the classifieds or in your area. The guys with CTR cams always think they are worth more and tend to go for a higher price
teamvirus
Aug 25, 2005 05:52 AM
integrasi
Aug 24, 2004 11:53 AM
PowerHouse
Apr 6, 2004 10:39 PM
CRX_GUY_123
13
Mar 28, 2004 06:54 PM
madhatch
Jun 23, 2003 10:37 AM
