turbo trouble
Old Aug 22, 2004 | 04:36 PM
96dcek's Avatar
Default turbo trouble
new to sight, i have a 96 gsr, i put a turbonetics kit on it and now im having trouble with it. it starts to sputter at around 4400-4500 or win vtec engages
i have a check valve and a 255 fuel pump and safc with injectors. i took it to a local shop but they couldn't help. any info would be great.
Old Aug 22, 2004 | 04:40 PM
jaydeemmmm's Avatar
Default Re: turbo trouble (96dcek)
Welcome.
I'm assuming you're running all 4 after market injectors? Do you have any additional injectors? It could be the fuel line or it could be your oil.
Old Aug 22, 2004 | 06:17 PM
DCApex8's Avatar
Might it be bad tuning, perhaps? I've heard of Vtec gettin in the way of boost before.
Old Aug 22, 2004 | 08:54 PM
GS-Rdriven's Avatar
Default Re: turbo trouble (jaydeemmmm)
wait until you can post in the FI section or ask a mod if they can move this for ya...you'll get more answer dataway
Old Aug 22, 2004 | 09:23 PM
iwannaboostmyteg's Avatar
I'd say its a problem with your vtec you need a controller for it and I'd recommend talking to the guys in the FI forum as soon as you can they have always helped me out with my questions.
Old Aug 23, 2004 | 04:36 PM
96dcek's Avatar
i have 4 400cc injectors
Old Aug 23, 2004 | 04:48 PM
shamoo's Avatar
Will you make something up for me please?
What are the specs of the Turbonetics kit you are using?
What psi are you running? Does that kit have (or do you have) any fuel modifications, such as an FMU or some other fuel management devide?
You have an S-AFC or do you have an V-AFC? You said S-AFC, but I'm just making sure.
EDIT: And you have a single check valve?
Modified by shamoo at 12:48 PM 8/24/2004
Old Aug 24, 2004 | 05:29 PM
96dcek's Avatar
Default Re: turbo trouble (shamoo)
im running 9psi i also have 255 fuel pump + 400cc injectors
S-AFC, single check valve
Old Aug 24, 2004 | 05:48 PM
foolintherain617's Avatar
vtec will do that stuff with turbo
they work against eachother more than together
Hush Racing
Mar 11, 2013 09:48 AM
93da9kid
Jan 30, 2011 07:08 AM
mooseknuckle
Mar 1, 2004 04:15 PM
Nick
Mar 20, 2002 12:47 AM
Acura97GSR
Mar 6, 2002 12:40 PM
