Injectors!?!
Old Mar 19, 2002 | 01:23 PM
Nick's Avatar
Default Injectors!?!
Pretty soon i plan on going turbo but i don't understand the concept of Injectors and what sizes to get. If i'm running just the Drag kit will i need to upgrade my injectors? I've been reading previous threads about people using the RC 440's and 550's but im not sure which applications i need.
Old Mar 19, 2002 | 02:37 PM
MiraiZ's Avatar
Default Re: Injectors!?! (Nick)
If you plan on doing a stand alone fuel system (modified ECU that can read boost and compensate by sending more fuel into the intake) you should get larger injectors to be able conpensate for the larger demand.
Larger injectors will never hurt...but be sure you have some kind of system (wheter it'd be a piggy back like a fuel controller) or complete stand alone that can recognize it. and use them correctly.
Old Mar 19, 2002 | 03:08 PM
Nick's Avatar
Default Re: Injectors!?! (MiraiZ)
Well i found a good deal on the RC 550's, will they work with just the turbo kit until i get a management system like Hondata?
Old Mar 19, 2002 | 03:19 PM
simike's Avatar
Maybe someone can answer this better but i think 310's is the max a factory ecu can still idle with. You can use a piggyback fuel controller but 550's i think are still to big. You need a stand alone for them.
Old Mar 19, 2002 | 03:25 PM
dwilson's Avatar
Default Re: Injectors!?! (simike)
Anybody, i would like to know about the piggy back deal . Are 550s to big for lets say a S- AFC
Old Mar 19, 2002 | 04:19 PM
DLB1994's Avatar
Default Re: Injectors!?! (dwilson)
on my car i idle 450cc with just the fuel psi turned down to 28psi and with no fuel
control
but i seen 550cc idle with a s-afc before with the fuel psi turn down
Old Mar 20, 2002 | 12:47 AM
MiraiZ's Avatar
Default Re: Injectors!?! (DLB1994)
Dude...lets put it this way...I made the mistake of buying a 'reliable' piggy back fuel system. A lot of people have good luck with these things, but I didn't. My car run so rich, that it smells like gas all the time....well I gave up! I got some 450cc's, an A'pex-i Power FC, and borrowed some cool looking maps...haven't put everything in yet, but I already know it'll be better than my current setup.
Moral of the story: Instead of wasting a $100 here, $400 there, etc...(which you will be doing to tune your car right) Just get a proven stand alone and some injectors and be done with it!
kyle-Lst
Apr 21, 2007 09:51 AM
yaya
Mar 14, 2004 05:07 PM
SUB-0 H23
Oct 20, 2003 09:58 PM
SpeedMonkeyRacing
Sep 7, 2002 08:13 AM
smoothludey2
Sep 6, 2001 06:48 PM
