throwing code, please help!
cel light came on and its throwing code 22! vtec oil pressure switch! i've tried changeing it and its still throwing a code, just trying to reset the ecu if that doesn't work any ides what else it could be?
Try and clear the code man. If everything went well,then once you pull the fuse to clear the code,when you hook everything back up and start the car the light should go out. If not either try clearing it again or check the problem again,make sure everything is hooked up. Also,check the code again. I had a problem,cleared one code and threw another right away. Good luck man.
..adam..
..adam..
