HELP WITH ALL MOTOR LS
i will be building a ls motor this winter but im now going to start buying the parts to build. i was thinking p30 pistons with crower 404's. i will have i/h/e already b/c the motor is already in my crx. the question i have is i want to have close to 12:1 comp.will i be able to mill the head to get that comp w/o a valve clearance problem? if i can mill it how much can i take off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx »</TD></TR><TR><TD CLASS="quote">i will be building a ls motor this winter but im now going to start buying the parts to build. i was thinking p30 pistons with crower 404's. i will have i/h/e already b/c the motor is already in my crx. the question i have is i want to have close to 12:1 comp.will i be able to mill the head to get that comp w/o a valve clearance problem? if i can mill it how much can i take off?</TD></TR></TABLE>
Hmm.. Acutally why would you want to go such high CR? the 404's only need 11:1 maybe 11.5 to work best. At 12:1 get a pair of 405a and make some real power! then watch for clearances however!
P.S. building a nonvtec allmotor myself. So far I got the 404's on a stock bottom and bolt ons. Got a P8R head however! GL with your build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">Hmm.. Acutally why would you want to go such high CR? the 404's only need 11:1 maybe 11.5 to work best. At 12:1 get a pair of 405a and make some real power! then watch for clearances however!
P.S. building a nonvtec allmotor myself. So far I got the 404's on a stock bottom and bolt ons. Got a P8R head however! GL with your build. </TD></TR></TABLE>
undercamming your engine =
Congratz on getting a P8R head, I keep my eyes open for one but doubt I will find one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx »</TD></TR><TR><TD CLASS="quote">i thought i needed higher than 11:1 to run the 404's. how streetable are the 404's? </TD></TR></TABLE>
Do some searches on dynamic compression, you will learn how to find out exactly how much Compression will be best for a given cam profile.
404s are beyond streetable.
LivingOutLoud
25
Aug 18, 2004 12:03 AM
