Car doesnt start......distributor?
I was driving my car and i got a CEL, which wast odd because i usually get a CEL when i get into boost at higher speeds/ 5th gear. The CEL is usually the CYP sensor wich is something is the distributor. I rolled to a stop sign, turned the car off to reset the hondata/ECU and when i went to turn the car again nothing..... The fuel pump will pressurize, then i turn the key and nothing no clicks, all i hear is the fuel pump priming the system again. If my distributor finally took a dump, would this prevent my car from even cranking over???
NotAJDMFanBoy
Aug 12, 2011 02:54 PM
LilCivic04
10
Oct 4, 2005 04:35 PM
