Car doesnt start......distributor?
Old Aug 21, 2004 | 09:07 AM
JR Integra's Avatar
Default Car doesnt start......distributor?
I was driving my car and i got a CEL, which wast odd because i usually get a CEL when i get into boost at higher speeds/ 5th gear. The CEL is usually the CYP sensor wich is something is the distributor. I rolled to a stop sign, turned the car off to reset the hondata/ECU and when i went to turn the car again nothing..... The fuel pump will pressurize, then i turn the key and nothing no clicks, all i hear is the fuel pump priming the system again. If my distributor finally took a dump, would this prevent my car from even cranking over???
Old Aug 21, 2004 | 09:41 AM
JR Integra's Avatar
Default Re: Car doesnt start......distributor? (JR Integra)
help.....anyone
Old Aug 21, 2004 | 10:14 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
when my distributor went out, the starter would still try and turn the car over.
is the CEL still coming on?
Old Aug 21, 2004 | 10:15 AM
oh yea, did you pull the battery cable and put it back on? that's helped me before.
Old Aug 21, 2004 | 10:38 AM
JR Integra's Avatar
Default Re: (MugenDude)
no CEL when i turn the key on, and i pulled the battery terminals.
Old Aug 21, 2004 | 12:48 PM
saleensolution's Avatar
Default Re: (JR Integra)
y changing out the dizzy to see if it makes a **** or not
Old Aug 21, 2004 | 06:38 PM
JR Integra's Avatar
Default Re: (saleensolution)
yea the ground wire came off the starter
NotAJDMFanBoy
Aug 12, 2011 02:54 PM
Tim2179
Honda Civic (2001 - 2005)
Dec 9, 2010 12:18 PM
d_EG COUPE
Jan 28, 2010 02:44 PM
ph0shizzle
May 9, 2007 05:57 AM
LilCivic04
10
Oct 4, 2005 04:35 PM
