how hot should your your engine be?
Old Aug 19, 2004 | 04:12 PM
Poopie's Avatar
Default how hot should your your engine be?
My block is 250+ valve cover is 215+ and exhaust manifold is close to 600. Sound about right? or am i over heating?
Old Aug 19, 2004 | 04:19 PM
civic_speed99's Avatar
Default Re: how hot should your your engine be? (Poopie)
Do you have a temp guage.... mine is never up over 1/4th of the way
Old Aug 19, 2004 | 04:25 PM
EK k kay's Avatar
Default Re: how hot should your your engine be? (civic_speed99)
My temp gauge never goes over 3/8. Sometimes I think it's broken. Once the car's all warmed up the needle goes up to 3/8 or real close to the 1/2 point and just stays there til I turn the car off.
Old Aug 19, 2004 | 04:27 PM
Poopie's Avatar
Default Re: how hot should your your engine be? (chowmien)
I have the same exact problem! How doy ou fix it? I may be having over heating problems so thats why I asked.
Old Aug 19, 2004 | 04:34 PM
EK k kay's Avatar
Not sure if it is even a problem. The valve cover does get very very hot after I drive around for like 20 mins (after warmed up). The headers get even hotter (duh).
Old Aug 19, 2004 | 08:38 PM
Poopie's Avatar
well i just thought 600 was a little extreme
Old Aug 19, 2004 | 08:43 PM
BatuKing's Avatar
what did you use to measure the temp of the engine?
also what was the ambient temp?
You need this to figure out temp. I think your meter was messed up because that's a pretty high figure.
Old Aug 19, 2004 | 08:56 PM
hond77's Avatar
Default Re: how hot should your your engine be? (BatuKing)
Your temp gauge should never pass the middle, otherwise, better check for a faulty waterpump or leaks.
Old Aug 20, 2004 | 06:45 AM
Poopie's Avatar
Default Re: how hot should your your engine be? (hond77)
I have a raytech laser infared temp gauge. Its pretty damrn accurate. Ambient temp was probably int he mid 70's. I have a whirring noise so it might be a faulty water pump. Will I have to replace the whole unit?
TshingY
Jan 25, 2010 12:59 PM
halocore
Sep 2, 2008 01:59 PM
nz_mike
Aug 24, 2007 02:54 PM
electric-boost
Dec 11, 2006 08:37 PM
Da1spaz247
Oct 12, 2005 02:33 PM
