i fugked up!!!
Old Aug 19, 2004 | 11:01 AM
KiNG $h!t's Avatar
Default i fugked up!!!
Ok yesterday i was out having alittle fun with my stock b16 ej1 coupe with bolt ons and a chipped ecu. Well we start to race and i miss a gear at 9k. Yes i know its a stock b16 your not supposed to rev a stock b16 to 9k i know.. just didnt realize i was that high till to late. Well anyways yeah after the race i heard a really loud *** clicking sound so i take it to the house and take of the valve cover to see that one of the nuts that go on top of the vavles and valve springs had flew off. So i put it back on and then i realize that my timing belt is so loose that you can almost put 2 fingers in between the belt and the cam gear!! well i go ahead and start the motor anyway to see if the motor was still clicking and sure enough it was. Not as bad as before when the nut was off but still has a low clicking noise to it.
Now the question is could it just be clicking from the timing being off so bad and from needing a valve adjustment? or is something else wrong?
Old Aug 19, 2004 | 11:05 AM
JDMotive's Avatar
Default Re: i fugked up!!! (this guy 2fast)
The clicking is from bent valves.Every single one of your valves is bent and it will cost you $2000 to get them replaced! ....J/K
If you heard a knocking noise or extremely loud clicking than it is you valves,but if its just a ticking even if semi loud than its most likely from valve clearance.If the adjuster nut flew off than most likely the clearance is way off which would cause the noise.Adjust it and put some tension back in your timing belt and you should be ok.
Old Aug 19, 2004 | 11:07 AM
KiNG $h!t's Avatar
thanx for the striaght forward help man... sometimes that is hard to get on h-t.
Old Aug 19, 2004 | 11:17 AM
alfaaay's Avatar
Default Re: (this guy 2fast)
How high did your RPM's go? After doing the valve adjustment and re-tensioning the timing belt, I'd recommend doing at least a compression test just to make sure nothing is out of whack. Bent valves suck . Hopefully you didn't bend any.
Old Aug 19, 2004 | 11:21 AM
KiNG $h!t's Avatar
werd . i hope i didnt bend any.. how safe is it to run on a bent valve?
Old Aug 19, 2004 | 11:23 AM
KiNG $h!t's Avatar
oh as far as the rpm's go i dont know i just saw it was at 9k when i missed the gear but i do let off the gas when i shift.
Old Aug 19, 2004 | 03:52 PM
KiNG $h!t's Avatar
Old Aug 19, 2004 | 04:37 PM
Fleas_Ef's Avatar
u should be fine but i agree get a compression test if bent upgrade to some nice valve train and get some cams in there
Old Aug 19, 2004 | 05:07 PM
hondaguyef's Avatar
Default Re: (Fleas_EF)
Adjust your valves, Make sure that the T belt did not jump teeth and then comp. test. Good luck bro, hope everything is OK.
Phil
Old Aug 19, 2004 | 07:29 PM
KiNG $h!t's Avatar
everything came out OK... no bent valves and and no more studdering from my ride feel real good now.
Old Aug 20, 2004 | 03:36 AM
hondaguyef's Avatar
Good stuff . Were the clearnces just way off from the jam nut flying off?
Phil
Old Aug 20, 2004 | 02:22 PM
KiNG $h!t's Avatar
yep they were off really bad and my belt was terribly loose. I was lucky i didnt just a tooth and bend a valve.
b18c198
Nov 7, 2005 10:06 AM
eg6turb0
Mar 3, 2005 07:24 PM
doublejz
Nov 5, 2003 06:46 AM
216.226.142.95:27016
Jul 15, 2003 07:16 PM
Ri5e
Sep 4, 2002 09:48 PM
