need help
Old Nov 2, 2005 | 08:21 PM
b18c198's Avatar
Default need help
Tonight while driving in 3th gear at 6k rpm I felt something snap or sorta give way while I was shifting form 3rd to 4th gear. I got out to check the noise I was hearing and saw that a bolt has forced itself through my vlave cover directly above my timing belt gears and timing belt. I do not have adjustable cam gears still stock. The noise is coming from inside the timing belt cover directly below my valve cover and also I smell like something is burning or rubber burnt. I have no idea until I get the valve cover off but has anyone else has this problem or know what may have happened here? I own a 98 GSR.
The car is fully drivable but the noise sounds like a tire rubbing against a wheel well or soemthing??? Any input is greatly appreciated. Thanks
***UPDATE*** pullled off the valve cover and found a bolt wedged between my timing blet and valve cover........too close!
Modified by b18c198 at 11:08 AM 11/7/2005
Old Nov 2, 2005 | 08:38 PM
b18c198's Avatar
Default Re: need help (b18c198)
come guys help me out here.........nobody?
Old Nov 2, 2005 | 09:41 PM
projectTeG's Avatar
pics?
Old Nov 3, 2005 | 12:50 PM
b18c198's Avatar
Default Re: (projectTeG)
[IMG][/IMG] http://memimage.cardomain.net/...l.jpg [IMG][/IMG]
Old Nov 3, 2005 | 01:03 PM
Wayne_Curr's Avatar
Default Re: (b18c198)
Um, looks like your timing belt is hosed obviously...maybe my eyesight just sux though...=/
Old Nov 3, 2005 | 01:13 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c198 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
It looks like you had that bolt trapped against your belt for a while. Look behind the timing cover to determine where it came from. You definitely need a new timing belt.
Old Nov 7, 2005 | 10:02 AM
acuramike's Avatar
IF IM NOT BLIND CHANGE THAT TIMING BELT AS SOON AS POSSIBLE, OR ***** GONNA COST YOU SOME SERIOUS CHEDDAR
Old Nov 7, 2005 | 10:06 AM
b18c198's Avatar
Default Re: need help (acuramike)
yea man the car is in the shop but that timing belt was brand new with only 600 miles on my forged internal rebuild...had it snapped and my motor would have been shot after I paid over 5k for the rebuild....too close!
B16b-EJ8
Apr 29, 2007 12:12 PM
SLATER97EX
Sep 18, 2003 04:55 PM
oryanh
Jul 8, 2002 10:33 AM
