b16 ticking
Old Nov 3, 2003 | 10:10 AM
doublejz's Avatar
Default b16 ticking
Ok this may seem wierd. When I am sitting in the car with the windows up at idle, i car hear a ticking, not just the noise of the valves that is normal to a b16. If I open the hood and listen I can't hear it at all. I did do a 5th gear to 2nd gear **** up and also turned the cam gear around when the timing belt was off, but I'm hoping its not a bent valve. Any ideas?
Old Nov 3, 2003 | 11:27 AM
SC0TT's Avatar
Default Re: b16 ticking (doublejz)
Does the ticking get louder from idle to around 3k then go away as you rev higher? I have this problem and was told it was caused by bad Lost Motion Assemblies (LMA's). Very common to b16a's, especially first gens.
Old Nov 3, 2003 | 11:51 AM
doublejz's Avatar
Default Re: b16 ticking (SC0TT)
i might, i dunno i just figured i couldn't hear it anymore due to my exhaust. It doesn't seem to get louder though.
Old Nov 3, 2003 | 04:54 PM
CleenSi
Guest
Posts: n/a
mite need a valve job
Old Nov 4, 2003 | 08:24 AM
doublejz's Avatar
Default Re: b16 ticking (CleenSi)
im gonna be pissed if i need new valves. They were just replaced.
Old Nov 5, 2003 | 06:46 AM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">im gonna be pissed if i need new valves. They were just replaced.</TD></TR></TABLE>
if they were just replaced, then maybe they need to be adjusted?
its not that expensie to get them adjusted...actually it shoudl be free if u had them replaced by sum1, bu if u did it it wont cost u that much.
Cadyfatcat
Aug 2, 2012 01:56 AM
b20beast83
Oct 19, 2009 05:42 AM
GSRBrent
Dec 2, 2007 09:25 PM
GoLowDrew
10
Jul 14, 2005 10:36 AM
dxhatch93
Jun 19, 2003 07:56 PM
