Exesive smoke from exaust on the DA?????help!
Old Aug 18, 2004 | 05:21 PM
92LsTegra's Avatar
Default Exesive smoke from exaust on the DA?????help!
ok,its a 92 integra Rs,sometimes sitting at idle theres more smoke than normalt coming from the tal pipe,(whitish),and from a stop and high rpms its smoks alot,wehn i race im considered the mosquito killer .what the hell could this be,and how much would it be to fix it,i have acess to a shop just need to know how to fix this damn thing..thanks in advance
Old Aug 18, 2004 | 05:38 PM
tsdenny's Avatar
Default Re: Exesive smoke from exaust on the DA?????help! (92LsTegra)
how many miles on the car?
Old Aug 18, 2004 | 05:45 PM
92LsTegra's Avatar
Default Re: Exesive smoke from exaust on the DA?????help! (6thgensohcvtec)
well im not exatcly sure theres 180 somethin on the body,and the moter is not the original,so im guessing b/t 100K and 140K.
Old Aug 18, 2004 | 06:25 PM
92LsTegra's Avatar
anyone????
Old Aug 18, 2004 | 06:33 PM
G1 TEGGY's Avatar
white smoke is coolant, you could have a crack somewhere or the head gasket might be going out, any leaks along the head and block mating point?
Old Aug 18, 2004 | 06:41 PM
PhantomSTi's Avatar
Default Re: Exesive smoke from exaust on the DA?????help! (G1_TEGGY)
Just come to Memorize these: White Smoke = Coolant. Blue Smoke = Oil. Black Smoke = Rich.
Old Aug 18, 2004 | 08:56 PM
3.504's Avatar
Default Re: Exesive smoke from exaust on the DA?????help! (90integra05)
white/grey smoke can also be lean. white smoke that has a sweet smell is coolant
Old Aug 19, 2004 | 02:21 PM
92LsTegra's Avatar
Default Re: Exesive smoke from exaust on the DA?????help! (3.504)
well im also running rich,there black smoke mixed with it,how can i edit how much fuel is being dumped(also my engine lights one,i got the codes to flash and im flashin o2 sensor #1,and fuel supply system)
Old Aug 19, 2004 | 02:33 PM
G1 TEGGY's Avatar
replace your fuel filter, check for any pinched lines, and replac that O2 sensor, that should eliminate the black smoke
Old Aug 19, 2004 | 04:59 PM
3.504's Avatar
those two codes are strictly o2... replace that, you should be running great.
i know 43 says "fuel supply system" but if you look at a honda manual, it says its all about the o2 sensor
Old Aug 19, 2004 | 06:42 PM
92LsTegra's Avatar
alright thanks alot guys,im taking it to our shop tomorow and probably going to order that sensor from napa,or acura/honda,be sure to check again and ill tell you how it went
Pelayo94
Apr 12, 2014 07:01 PM
R-1303
Nov 26, 2002 01:41 AM
LSyellowREX
Aug 1, 2002 11:37 AM
immortal
Nov 3, 2001 03:23 PM
