thinking of doing h22 head on h23 block and going turbo is it possible ?
Old Aug 18, 2004 | 10:07 AM
BLACK_DEL_SOL's Avatar
Default thinking of doing h22 head on h23 block and going turbo is it possible ?
ive heard that once you do the h23 vtec swap you cant go turbo is that true ?
Old Aug 18, 2004 | 10:22 AM
matix's Avatar
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (BLACK_DEL_SOL)
from what i remeber the h23 vtec likes boost more then a h22. It has lower compression and can handle more boost then a h22.
Old Aug 18, 2004 | 10:25 AM
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (matix)
i wa told that the compression was too high to put boost on it , and if you did boost i had to be low . im trying to get 200-250 hp out of the engine
Old Aug 18, 2004 | 11:20 AM
TxTuner
Guest
Posts: n/a
Your best bet is to just boost the 23. If you still want VTec, do the head swap and just get lower compression pistons.
Old Aug 18, 2004 | 11:27 AM
H23 Power's Avatar
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (TxTuner)
an H22 head on a stock H23 block will yield rougly 9.3:1 compression
Old Aug 18, 2004 | 12:09 PM
SKDRCR's Avatar
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (H23 Power)
of course it's possibile.
I believe there is a guy on here that's running 10s
in his h23vtec turbo hatch
Old Aug 18, 2004 | 12:29 PM
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (SKDRCR)
nice, in your guys opinion whats worth it a turbo h23 or do a h23 vtec swap maybe turbo ?
Old Aug 18, 2004 | 12:31 PM
SKDRCR's Avatar
you should decide first wether or not you want to go the all-motor
or turbo route. If i was going turbo, i would just build the regular h23
up (forged internals etc.)
Old Aug 18, 2004 | 12:48 PM
what if i rebuild the engine stock ,no after market parts would it be able to take 10 lbs of boost ?
Old Aug 18, 2004 | 12:52 PM
Kal's Avatar
Kal
very unlikely, there are very few that can handle that above 8lbs of boost because of the weak ringlands of the h-series motors. But it can be done, there have been people to run 10+ lbs of boost on stock motors.
Old Aug 18, 2004 | 01:18 PM
Default Re: thinking of doing h22 head on h23 block and going turbo is it possible ? (Kal)
then what kind of upgrades would i need to run 10 lbs of boost
Old Aug 18, 2004 | 01:43 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL &raquo;</TD></TR><TR><TD CLASS="quote">then what kind of upgrades would i need to run 10 lbs of boost</TD></TR></TABLE>
A very good engine management system and a very good tuner.
Old Aug 18, 2004 | 10:26 PM
honda head's Avatar
I dont know much about boosting preludes I can however tell you what you might need.
Right, you are going to need some kind of ems, you might want to rebuild your engine " with aftermarket parts like forged rods and pistons" just to be safe, especially if your car is a daily driver and you rag on it alot. Upgrade your fuel rail, injectors, lines and fuel pump, you also might want to get some ajustable cam gears so you can tweek to cam timing to flush air in and out of your engine. A upgraded ignition would help too.Stay away from cast iron turbo manifolds they may crack if they get to hot, get a stainless steel tubular manifold they have equal legth runers for a faster spool. When it comes to the turbo get a set up that allows an external wastgate because internaly gated units can boost creep under high boosting "and things may go boom!" also a 3in.diam. exhaust. For more info check out the turbo section of this forum.
Old Aug 19, 2004 | 04:44 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL &raquo;</TD></TR><TR><TD CLASS="quote">i wa told that the compression was too high to put boost on it , and if you did boost i had to be low . im trying to get 200-250 hp out of the engine</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">an H22 head on a stock H23 block will yield rougly 9.3:1 compression</TD></TR></TABLE>
If you are planning on boosting the h23 vtec is an awesome motor... Tons of torque AND high end vtec power.... And like H23 Power said, if you just put an h22 head on an h23 block without touching the bottom end, it will give you a great compression ratio for boosting... That is exactly why I built my motor...
Dabrybry
Apr 17, 2009 11:45 AM
crxsi541
Jul 27, 2005 03:36 PM
NeKe1point0
Sep 18, 2004 08:04 PM
95luda
Jul 5, 2004 08:22 AM
lude92si
Apr 11, 2003 03:33 PM
