will a y7 work?
i have a 98 ex y8 with a spun bearing and have found a y7 bottom end
will it bolt right up to my head?
im hearing that i might have to do something with the knock sensor
and links would be nice
and advice
the guy is waiting on me to tell him if i want the motor
thanks all
jman
and advice
thanks all
jman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">yup, it'll work fine since the Y7s have a knock sensor too.</TD></TR></TABLE>
Mine doesn't have it....
Do you mean they have a threaded boss to screw one in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy »</TD></TR><TR><TD CLASS="quote">a d is a d no matter how you look at it and you do not need a knock sensor for v-tec.</TD></TR></TABLE>
Tell that to the Y8 ECU....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jman30513 »</TD></TR><TR><TD CLASS="quote">i believe the y7 doesnt have a knock sensor hole?</TD></TR></TABLE>
It has a threaded hole for one, Y7/Y8 blocks are exactly the saem, except for the sleeves
isnt the knock sensor on the head and i think the knock is only neccesary for dual cam. motors.. a single will run vtec fine with the vtec wire and oil pressure or whatever that 2nd wire is. im pretty sure not the expert though. just but a d16z6 bottom end or zc vtec y test it doing a mini me. may create more power then the stock y8 does though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota »</TD></TR><TR><TD CLASS="quote">spade... y7's have knock sensors?... last couple y7's i've worked on that was a negative bro</TD></TR></TABLE>
I meant that the Y7 has a boss for the knock.......not drinking coffee in the morning ownz me.
I meant that the Y7 has a boss for the knock.......not drinking coffee in the morning ownz me.</TD></TR></TABLE>
Ya right you colorbind bastage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Okay you got me.......I'm stupid and I don't know anything, never listen to what I say cause I don't know ****
EDIT: GDamn noobie mods
</TD></TR></TABLE>Okay you got me.......I'm stupid and I don't know anything, never listen to what I say cause I don't know ****
EK_vzla
Feb 3, 2004 06:32 AM
