Wiring Diagram for 98-99 Type R cluster in civic?
Does anyone have the cluster wiring diagram for a 98-99 integra type r cluster into a civic, not the 94-95 gsr diagram everyone posts up, because the coloured wires are different from the civic to the integra.....
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
More info soon...</TD></TR></TABLE>
I have the diagrams at home if you need anymore.
HOWEVER
Why?
This is why:
Kaboom -- done.
see this is the problem the 98+ integra harness the green plug will not plug into the civic fuse box and either will the grey plug with having to repin it, that is why I am just going to use the civic harness and repin the cluster side, if someone has a up to date article or wire diagram that would be great, but I no 100% that the wires don't match colour per colour
I used the search function and couldn't find the answer I was looking for that is why I posted, clearly if you think the pins are in the same spots you are mistaken and you should use the search function and maybe learn something today instead of saying "use the search function". Because a civic has a 10 and 12 pin plug while the integra uses a 13 and 16 pin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning »</TD></TR><TR><TD CLASS="quote">use the search function.. the wire colors are different, but the pin locations should be the same...</TD></TR></TABLE>
you got served
TTT so this guy gets some real answers
you got served
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio »</TD></TR><TR><TD CLASS="quote">I used the search function and couldn't find the answer I was looking for that is why I posted, clearly if you think the pins are in the same spots you are mistaken and you should use the search function and maybe learn something today instead of saying "use the search function". Because a civic has a 10 and 12 pin plug while the integra uses a 13 and 16 pin
</TD></TR></TABLE>Have you checked the archives? Secondly, I was referring to the Integra clips being in the same locations (94-97) / (98+). Maybe you misunderstood me when I said "wire colors are different, locations should be the same". I just did the same conversion for a friend's EG, and it wasn't that hard. I wasn't trying to be a smart ***, just trying to help. I'll remember this type of attitude next time you're needing some help.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio »</TD></TR><TR><TD CLASS="quote">what help have you provided?
lol. but nonetheless, he gave you free bumps y0!
</TD></TR></TABLE>lol. but nonetheless, he gave you free bumps y0!
Here ya go buddy.. took me less than 2 minutes to use the search function my friend. there's more threads out there.. just search the archives. it takes a lil time to find a good source, but here's 2 that I used that are really good. You're welcome!
https://honda-tech.com/zerothread?id=782161
https://honda-tech.com/zerothread?id=600468
follow this diagram that you could have found if you did a search and it will work correctly.. i have had it done since Feb and no problems at all...
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
I used the same one for the conversion i did. The colors don't need to match so long as your pins are matched.
</TD></TR></TABLE>Here ya go buddy.. took me less than 2 minutes to use the search function my friend. there's more threads out there.. just search the archives. it takes a lil time to find a good source, but here's 2 that I used that are really good. You're welcome!
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0ni »</TD></TR><TR><TD CLASS="quote">
you got served
TTT so this guy gets some real answers</TD></TR></TABLE>
not to be an ***, but where's the help you've provided?
you got served
na.. that's cool yO.. i'm here to get information and share what I know.. I dont' have a problem explaining thing to people who ask respectfully. If i find I'm wrong about something in the process, that's just a learning experience for me as well.
But the teggie clips have the pins in the same location, except the wires are different colors among the years they were made. and that does not make a difference. Just Identify them on the clip and label them , you'll be fine.. hope it helps. I'm in Minnapolis, so if you need help, just IM me.
actually no they don't, that's why I posted it in the first place, but either way I solved my problem by going to my buddies shop and using the mitchels on demand
, that wiring diagram is completly wrong with 98-99
AIWFCIATR
Sep 24, 2004 12:37 AM
b16ferio
Feb 24, 2004 08:35 AM
