Registering a 95 Civic with a H22 Swap
Old Aug 17, 2004 | 10:04 PM
dacosta's Avatar
Default Registering a 95 Civic with a H22 Swap
I have a 95 civic hatch with a h22 engine in it and need advise on what I need to get it state certified in Ca.
Thanks in advance.
Old Aug 18, 2004 | 06:02 AM
v4lu3s's Avatar
RTFM
You need to go see a referee and get a BAR sticker usually.
Old Aug 18, 2004 | 07:20 AM
dacosta's Avatar
Default Re: (v4lu3s)
I've been hearing that I would need to get my ecu verified first...is that correct or would the P13 JDM ECU be acceptable?
I have been hearing that the P13 USDM ECU & JDM ECU are literally the same emission wise.
Old Aug 22, 2004 | 07:20 PM
dacosta's Avatar
Default Re: (dacosta)
Has anyone had success on having a civic with a jdm h22 swap state referee'd with a jdm p13 ecu?
Old Aug 27, 2004 | 02:28 PM
dacosta's Avatar
bump
Old Sep 3, 2004 | 10:33 AM
dacosta's Avatar
Now have a cool bar sticker on my car....hooray
Thanks to those who helped!!!
Hybrid Automotive & Fellow Honda-Tech Members .
Old Sep 3, 2004 | 11:33 AM
DIE DIE's Avatar
as long as the motor is 95 or newer you shouldn't have a problem.
Old Sep 3, 2004 | 11:44 AM
BrokeLude's Avatar
So what did you have to do to get it done?
Old Sep 3, 2004 | 02:35 PM
dacosta's Avatar
Default Re: (BrokeLude)
Are you referring to get the car to pass the referree or to get the swap done?
Old Sep 3, 2004 | 02:39 PM
stRodda's Avatar
how'd you get it refereed? i have a 91 accord with a swap, but i thought some emissions stuff was missing from jdm engines. and i dont have my stock ecu, only a chipped p72.
Old Sep 3, 2004 | 07:14 PM
dacosta's Avatar
Default Re: (stRodda)
Actually, the JDM Engine does have all the necessary components necessary for the it to pass CA emissions. That or the swap that I got just happened to come with everything.
Anyway, one thing that you would definitely need would be the USDM P13 ECU for the engine that you have.
Once you have that, you should be all set. Oh be sure that if you engine is OBD1 that you have an OBD1 ECU.
Also, be sure that you don't have any loose or excessively long wires hanging out(Make sure they are all zipped tied and wrapped in electric tape as necessary).
The same with any rubber hoses(be sure that they are all clamped done nice & tight).
The number I called for the referee appointment is 1-800-622-7733
Old Sep 25, 2004 | 10:50 AM
dacosta's Avatar
Old Sep 25, 2004 | 11:28 AM
Monkey Fing a Coconut's Avatar
everything u need to know
https://honda-tech.com/zerothread?id=974341
dacosta
15
Sep 3, 2004 02:33 PM
silverh22
Jun 8, 2003 10:02 AM
