what # fuel pump & injectors for jrsc???
Old Aug 17, 2004 | 07:43 PM
tegon-gsr's Avatar
Default what # fuel pump & injectors for jrsc???
I have b18c1 motor with type are cams all bolt ons hondata with boost and want to run 8-10 of boost what fuel pump and injector should i get ???
Old Aug 17, 2004 | 08:29 PM
11psiTurboSI's Avatar
Default Re: what # fuel pump & injectors for jrsc??? (tegon-gsr)
Walbro GSS-342 (high output) fuel pump and 440cc injectors
Old Aug 17, 2004 | 08:43 PM
illi Adik's Avatar
Default Re: what # fuel pump & injectors for jrsc??? (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Walbro GSS-342 (high output) fuel pump and 440cc injectors</TD></TR></TABLE>
Yes sir, the 255lph pump.
Old Aug 17, 2004 | 08:46 PM
91civicEX's Avatar
im runnin a walbro 255 and dsm 440s on a jrsc d16. runs good. if you plan on uppin the boost u might want to look into some bigger injectors
Old Aug 17, 2004 | 09:38 PM
illi Adik's Avatar
Default Re: what # fuel pump & injectors for jrsc??? (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">im runnin a walbro 255 and dsm 440s on a jrsc d16. runs good. if you plan on uppin the boost u might want to look into some bigger injectors</TD></TR></TABLE>
I HIGHLY doubt hes gonna use all of the 440 Injector w/ the Jackson unless he plans on spraying on it.
Tegon: I'm located right in Frederick so lemme know if you even need some help with anything...I used to have the JRSC so I know a thing or two about it.
Old Aug 18, 2004 | 08:01 AM
tegon-gsr's Avatar
Default Re: what # fuel pump & injectors for jrsc??? (Jackson4Door)
thanks guysfor the help I here people talking about satrated and non sat. whats the diffrence?
Old Aug 18, 2004 | 01:29 PM
91civicEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson4Door &raquo;</TD></TR><TR><TD CLASS="quote">
im just sayin that because on my uberdata map it says at 10psi and near 9k rpm my injectors are at 110% duty cycle. its fine for me since i boost 6psi never above 8k. could be different for him. also im on just a basemap for a few more days so it might be rich.
and saturated vs non saturated just means one uses an injector box and one doesnt. i forgot which is which though,
Old Aug 20, 2004 | 12:05 PM
tegon-gsr's Avatar
thanks
Old Aug 21, 2004 | 11:11 AM
HYREV2NR's Avatar
I have a SC on my 01 Type r w/ the stock pump & no probs. A bud of mine has a 95 Si H/B with a GSR motor, JRSC, & it's Hondata tuned with 10 lbs. of boost & the stock Si pump. It's smokes alot of modified street cars both import & domestic.
escape2me
Sep 30, 2005 07:29 AM
HT Chaplain
Dec 19, 2003 12:24 PM
92TEGsrSC
Jul 7, 2003 09:16 AM
smoothludey2
Oct 1, 2001 03:27 PM
