Injector upgrade necesary?
Do you know where i can get some obdo 440's? I know 89 eclipse turbos are 450's and 91mr2 turbo's are 440's would those plug right in?
Modified by legutki at 3:44 PM 12/19/2003
Yeah i got a used kit and it comes with a fuel pump and a 9 psi upgrade pulley so i wondering what i have to do for the 9psi I know i need bigger injectors so im trying to see which ones would work for a obdo car.
I guess it would depend on your fuel management. If your going Hondata, sure get bigger injectors. If your going with a VAFC then your injector choices are limited. If your just going to run a FMU then bigger injectors will prob run like **** with the stock ECU.
