Check Engine Light
Old Aug 17, 2004 | 03:54 PM
Leviata-N's Avatar
Default Check Engine Light
Hey I check my dash and I see the engine ligth on, so I try to know the code and when I did it, this comes out
Ligth on(check engine ligth): large period
then
Ligth on: large period
then small pause and
Light on: short period
then big pause and
3 times ligth on short period.
What can this mean¿?
Old Aug 17, 2004 | 03:57 PM
germz's Avatar
Default Re: Check Engine Light (Leviata-N)
https://honda-tech.com/zerothread?id=682412
this should help you
Old Aug 17, 2004 | 03:58 PM
handa's Avatar
can you explain it in shorter terms please?:
long-long-short-short-short=23
EDIT: nevermind...
Old Aug 17, 2004 | 04:07 PM
Leviata-N's Avatar
Default Re: Check Engine Light (handa)
Yes it is
long long short
the a big pause and
short short short
Old Aug 17, 2004 | 04:09 PM
handa's Avatar
sounds like a:
long-long-short = 21 (VTEC spool solenoid valve)
short-short-short= 3 (MAP - manifold absolute pressure sensor)
Old Aug 17, 2004 | 04:10 PM
Leviata-N's Avatar
What this spool solenoid valve do?
Old Aug 17, 2004 | 04:13 PM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N &raquo;</TD></TR><TR><TD CLASS="quote">What this spool solenoid valve do?
that's your VTEC solenoid valve, without it you can't have VTEC at all.
Old Aug 17, 2004 | 04:18 PM
Leviata-N's Avatar
Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy
Old Aug 17, 2004 | 04:21 PM
donkiman's Avatar
Old Aug 17, 2004 | 04:25 PM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N &raquo;</TD></TR><TR><TD CLASS="quote">Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy</TD></TR></TABLE>
yes, a bad wire onto the motor electrical circuit will cause it to go haywire and sensors to not perform right. make sure your motor is well grounded.
from experience, a friend's car wouldn't start and his odometer goes up to 70mph when cranking...all due to bad ground wires.
CARflyGUY
Dec 15, 2006 03:02 PM
JDM00SI
Aug 25, 2004 05:42 AM
ramz7887
17
Nov 6, 2003 04:37 AM
Joe Foe
Apr 22, 2002 03:13 PM
