Check Engine Light
Hey I check my dash and I see the engine ligth on, so I try to know the code and when I did it, this comes out
Ligth on(check engine ligth): large period then Ligth on: large period then small pause and Light on: short period then big pause and 3 times ligth on short period. What can this mean¿? |
Re: Check Engine Light (Leviata-N)
can you explain it in shorter terms please?:
long-long-short-short-short=23 EDIT: nevermind... |
Re: Check Engine Light (handa)
Yes it is
long long short the a big pause and short short short |
sounds like a:
long-long-short = 21 (VTEC spool solenoid valve) short-short-short= 3 (MAP - manifold absolute pressure sensor) https://honda-tech.com/forums/images/smilies/emthup.gif |
What this spool solenoid valve do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N »</TD></TR><TR><TD CLASS="quote">What this spool solenoid valve do?
</TD></TR></TABLE> that's your VTEC solenoid valve, without it you can't have VTEC at all. |
Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N »</TD></TR><TR><TD CLASS="quote">Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy</TD></TR></TABLE>
yes, a bad wire onto the motor electrical circuit will cause it to go haywire and sensors to not perform right. make sure your motor is well grounded. https://honda-tech.com/forums/images/smilies/emthup.gif from experience, a friend's car wouldn't start and his odometer goes up to 70mph when cranking...all due to bad ground wires. https://honda-tech.com/forums/images...s/emsmilep.gif |
