Check Engine Light
Check Engine Light
Hey I check my dash and I see the engine ligth on, so I try to know the code and when I did it, this comes out
Ligth on(check engine ligth): large period
then
Ligth on: large period
then small pause and
Light on: short period
then big pause and
3 times ligth on short period.
What can this mean¿?
then
then big pause and
Re: Check Engine Light (Leviata-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N »</TD></TR><TR><TD CLASS="quote">What this spool solenoid valve do?
that's your VTEC solenoid valve, without it you can't have VTEC at all.
Re: Check Engine Light (handa)
Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N »</TD></TR><TR><TD CLASS="quote">Ok, a small question, I my spark plug wires are in bad shape, so may be some is jumping in to the valve cover, so the engine is - and this electricity is + so can this make the ECU go crazy</TD></TR></TABLE>
yes, a bad wire onto the motor electrical circuit will cause it to go haywire and sensors to not perform right. make sure your motor is well grounded.
from experience, a friend's car wouldn't start and his odometer goes up to 70mph when cranking...all due to bad ground wires.
ramz7887
17
11-06-2003 04:37 AM
