ABS light still on
Old Aug 17, 2004 | 02:29 PM
M2nR's Avatar
Default ABS light still on
hey i got a 95 accord and the ABS indicator light turned on...so i take it to the dealer and have the 60,000 mile tune up and ****, they said everythings fine and yet the ABS light is still on...does anybody know what it could be?? i already searched but its just not that specific...any help would be great thx!
Old Aug 17, 2004 | 02:43 PM
Chiovnidca's Avatar
Default Re: ABS light still on (M2nR22)
What trouble code does it have stored?
Old Aug 17, 2004 | 04:03 PM
SuperSlow's Avatar
Default Re: ABS light still on (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">What trouble code does it have stored?</TD></TR></TABLE>
Did not know that ABS light will throw a trouble code....
Anyway, try pulling the fuse and replacing it.
Old Aug 19, 2004 | 08:56 PM
M2nR's Avatar
Default Re: ABS light still on (SuperSlow)
nah it wasnt the fuse
anymore ideas???
and nah its not throwing any codes..
Old Aug 20, 2004 | 05:59 AM
95exrv6's Avatar
flushes your fluids
you either have air bocket in the brake lines
or air pocket in the aba modulator
just bleak them out flush the abs fluid
it'll be the best 30 $ you've spent
and if you want to the rad, engine and tranny oil at the same time
your accord will thank you
Old Aug 20, 2004 | 10:11 AM
RotaryBzzzz's Avatar
Default Re: ABS light still on (95exrv6)
see my signature.
Old Aug 21, 2004 | 08:46 PM
hacd5's Avatar
Default Re: ABS light still on (RotaryBzzzz)
i have the ABS problem too. When i put the car into gear and drive for 3-5 secs the ABS light turns on and I hear a clicking sound near the glove box. How do i check for the ABS codes? What connectors do i connect? i am confused.. please help
Old Aug 21, 2004 | 08:49 PM
fw190bvi's Avatar
Default Re: ABS light still on (hacd5)
if youve flushed everything out and its still on, your fine, you just wont have ABS......its overrated anyways
Old Aug 21, 2004 | 08:51 PM
hacd5's Avatar
Default Re: ABS light still on (fw190bvi)
yeh ill give that a try...but i would also like to know how to check the codes...anyone ?
Old Aug 22, 2004 | 08:02 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hacd5 &raquo;</TD></TR><TR><TD CLASS="quote">...but i would also like to know how to check the codes...anyone ?</TD></TR></TABLE>
Jump the service check connector like you would a CEL. It should flash a code quickly followed by a sub-code.
Old Aug 24, 2004 | 07:49 AM
endresen's Avatar
I do know the clicking sounds are the ABS relays in the engine compartment. That used to make me wonder too.
sneakerfern
Feb 20, 2007 04:37 PM
mstewar
Jan 22, 2007 09:04 AM
seraniko
Sep 8, 2005 01:44 PM
BigChris
Jun 13, 2004 09:42 PM
GSblueRacing
May 6, 2003 09:21 PM
