ABS light came on. what to do?
Driving around,ABS light wasn't on, After driving for a while, the Light came on and stayed on. Then I turned engine off and waited 5 mins. Turned engine on as usual ABS light stayed on for 2 seconds and went off as usual, but it didn't come back on again.
What caused the ABS to light upn when i was driving before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrocket21 »</TD></TR><TR><TD CLASS="quote">get the code checked</TD></TR></TABLE>
what code? I don't have the factory stereo unit.. I have aftermarket.
anyone had this ABS problem before? how to fix it? if it even need to be fixed.
You should have it checked out. You can start with checking the abs fluid level. It's been known that a bad o-ring can cause the fluid to leak and/or trip the abs light.
As others have said, first thing you should do is check your brake fluid level for your ABS reservoir. If that isn't the culprit, then you're going to have to jump the service connector with a paper clip. Read the flashes and pull the code from there.
Also, if you use the Search function, you'd find that there are at least 10 threads about ABS lights coming on.
newhondaowner29
Jan 11, 2006 08:11 PM
