When I shift, my car rocks, when I take my foot off the gas, my car rocks....HELP!!!
Old Aug 17, 2004 | 11:18 AM
Weapon_R's Avatar
Default When I shift, my car rocks, when I take my foot off the gas, my car rocks....HELP!!!
I have a feeling that it is the motor mounts. When i shift gears, the entire car rocks back and force for a second and then normal driving until I shift again. Also, if I take my foot off the gas, it rocks, when i press the gas, it rocks again.
Would some Energy Suspension mount inserts fix this?
Old Aug 17, 2004 | 11:26 AM
Cliffjumper2's Avatar
Default Re: When I shift, my car rocks, when I take my foot off the gas, my car rocks....HELP!!! (MickeyA)
check your motor mounts, especially the one on the tranny. The inserts might fix it depending on what is broken. When checking your mounts, if you see that it's just the rubber bushing that has cracked, then the energy or Prothane (my choice ) should fix this problem.
When this happened to my last teg, I had custom solid race mounts installed, it was a bit harsher ride, but I loved it.
Old Aug 17, 2004 | 11:29 AM
Dan GSR's Avatar
Default Re: When I shift, my car rocks, when I take my foot off the gas, my car rocks....HELP!!! (DCcliffjum
def the motor mounts
do all 5 motor mounts
Old Aug 17, 2004 | 12:31 PM
peacexisxfree's Avatar
yup, definately motor mounts. go with some energy suspension motor mounts and make sure everything is really tight, it makes a hell of a difference
exhale
Sep 7, 2007 05:30 PM
civic_driver
Nov 1, 2005 10:22 AM
Novtecdohc
May 15, 2005 05:24 PM
ID_ten_T
Sep 19, 2004 12:26 PM
spencedogg
Nov 2, 2003 09:06 AM
