Boosted b18b guys running hondata. Timing question
What do most of you stock boosted b18b guys have your timing set at on the distributor and hondata?
Mine is set at 16 degrees on the distributor and my Total timing is set at 22. I am running NGK 9step colder plugs,93 octane, on 10.5psi on a bone stock b18b. Im actually on 5psi right now. But I was tuned for 10.5psi. I laid down 259whp @ 211wtq on a dynojet with 4th gear pulls.
Khoi
Modified by Sohc Driver at 11:29 AM 8/17/2004
Khoi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">What do most of you stock boosted b18b guys have your timing set at on the distributor and hondata?
Khoi
Modified by Sohc Driver at 11:29 AM 8/17/2004</TD></TR></TABLE>
I think that is fine. 16 is the standard at the distributor. 22@10 is fine but not conservative by any means. (I would consider 18 conservative)
9 Series plugs are WAY to cold for your app. You need some 7's in there.
Good luck.
Khoi
Good luck.
bnmm
Engine Management and Tuning
Jun 22, 2013 05:29 AM
