setting ignition timing on b18b
Old Mar 8, 2002 | 02:34 PM
fo-do's Avatar
New User
Default setting ignition timing on b18b
i did a search but it didn't really answer my question..... what i wanna know is who here has adjusted/set their ignition timing (via rotating the distributor, like it describes on the c-speed racing site in the "how to" section).
i have a b18b that i would like to set at 18 degrees btc.... so far my research has confirmed that that is a safe place to set it at and will give me the most gains.
those who have done it to their LS's.... how do you like it? did you notice anything? i only have a butt dyno so that's what i'm going on...
thanks in advance for the replies.
Old Mar 8, 2002 | 03:19 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: setting ignition timing on b18b (fo-do)
You won't notice ignition advance on a "butt-dyno."
The gains might only be fuel efficiency....and not much at that.
18 degrees should be safe. Your motor suggests 16 plus/minus 2 degrees BTDC.
frank358fr
Sep 19, 2014 12:24 PM
ekhatch66
Engine Management and Tuning
Aug 23, 2009 03:45 PM
mortificationrock
13
Oct 7, 2007 09:08 PM
emotionisdead
Dec 23, 2004 03:52 PM
bOOsTiNSoHcVtEc
Mar 26, 2004 08:44 AM
