Hole in tranny - add ins (trans, transmission)
Old Aug 16, 2004 | 10:13 PM
plusONE jboy's Avatar
Default Hole in tranny - add ins (trans, transmission)
Was changing my oil the other day and noticed this hole in the bottom of my transmission...
picture of the hole
close up of the hole..
What could of caused this? Is it still ok to use this tranny?
Old Aug 17, 2004 | 07:19 AM
torr's Avatar
Default Re: Hole in tranny - add ins (j boy)
yeah you can use it, looks like something hit your clutch housing, a rock maybe? may get a little dirty and dusty inside.
Old Aug 17, 2004 | 08:01 AM
sullenht's Avatar
Default Re: Hole in tranny - add ins (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">I wish I can install hondata on my girlfriend so I can tune her mouth shut..</TD></TR></TABLE>
lmfao
Old Aug 17, 2004 | 08:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can use it, looks like something hit your clutch housing, a rock maybe? may get a little dirty and dusty inside.</TD></TR></TABLE>
So you dont think anything is wrong inside of my tranny?
Old Aug 17, 2004 | 12:12 PM
ek_99_SiR's Avatar
jb weld?
Old Aug 17, 2004 | 12:39 PM
DxVteC's Avatar
If i were you i would get that fixed as soon as possible because dirt and oil may enter the bell housing and get on the clutch, which will cause your clutch to start slipping and wear faster than normal. Aslo that crack will cause your transmission housing to be that much more weaker. Sooner you get it fixed the less you'll suffer in the long run.
Old Aug 18, 2004 | 09:30 AM
can can i just have that welded up? and where would i go for something like this?
Old Aug 18, 2004 | 09:34 AM
JDMotive's Avatar
Default Re: (j boy)
It was most likely from bottoming out on a big rock or something similar.It will be ok though.Though it would be best to get it welded up or at least jb weld something on it to cover it up,its not 100% necessary.Ive run thousand's of miles without the flywheel shield on many of my cars and have had no problems..it just helps prevent any large objects from entering the bell housing and possibly causing something to happen.Like I said though,ive never had a problem,but that doesnt mean you wont.
Old Aug 18, 2004 | 07:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">It was most likely from bottoming out on a big rock or something similar.It will be ok though.Though it would be best to get it welded up or at least jb weld something on it to cover it up,its not 100% necessary.Ive run thousand's of miles without the flywheel shield on many of my cars and have had no problems..it just helps prevent any large objects from entering the bell housing and possibly causing something to happen.Like I said though,ive never had a problem,but that doesnt mean you wont.</TD></TR></TABLE>
cool, thanks for the heads up.
anybody with other suggestions feel free to post.
Old Aug 21, 2004 | 07:55 PM
bump
Old Aug 21, 2004 | 08:39 PM
HATCHingMN's Avatar
Default Re: Hole in tranny - add ins (1.6i-16zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i-16zc &raquo;</TD></TR><TR><TD CLASS="quote">jb weld?</TD></TR></TABLE>
Yep
Old Oct 6, 2005 | 02:19 PM
Makdaddynuge's Avatar
Default Re: Hole in tranny - add ins (HATCHingMN)
My 98+ jdm itr tranny has a quarter size hole in it on the bottem side where it meets the block. I have the "type r dust shield", so said the guy i bought the car from, so what exactly is that and should i still get that hole welded up?
Modified by Makdaddynuge at 4:09 PM 10/6/2005
Old Oct 6, 2005 | 03:46 PM
bump...need answer
I don't wanna start a new thread over this
hammergunner
Sep 11, 2008 08:00 PM
ivt-t
May 26, 2008 05:56 PM
neo_
Dec 8, 2006 03:57 PM
jmk2888
Sep 17, 2004 02:04 PM
RhombeusGSR
Jun 28, 2004 12:02 PM
