Odd TPS voltage problem
Old Aug 16, 2004 | 05:43 PM
kagegod's Avatar
Default Odd TPS voltage problem
So I'm having a problems with my TPS (go figure). I'm not throwing a code until I go WOT. I checked the TPS trying to adjust the voltage to read .45 idle yet when I check it's reading 2.22 at closed. If I adjust it it adjusts up to 2.46 at closed. has anyone had this problem before? As long as I stay under 1/2 throttle the TPS works fine and I don't get a code but what fun is that with a fresh B16 swap in it?
Old Aug 16, 2004 | 07:23 PM
kagegod's Avatar
bump would like to get some input on this if someone's had a similar problem
Old Aug 16, 2004 | 07:36 PM
abnaasefmb's Avatar
Default Re: (kagegod)
you should have 4.5 volts at wot. might be bad sensor
Old Aug 16, 2004 | 07:59 PM
kagegod's Avatar
That'd make the second bad sensor I bought but there has to be a reason for it. The other TPS I used registered negative voltage so at least this one won't throw a code until I got WOT
Pinarr
May 18, 2012 08:36 AM
Devious951
Sep 18, 2009 05:11 PM
rhdins
Jul 20, 2008 05:12 AM
crnimacak
Jan 19, 2006 04:59 PM
Forrest Gump 9
Apr 26, 2005 09:05 PM
