S2 IM & PR solid mounts installation pics
Old Aug 16, 2004 | 06:26 AM
VSBB6's Avatar
Default S2 IM & PR solid mounts installation pics
Remove Spoon bar
Stock IM removed
OEM rear mount
PR rear mount installed
OEM front mount
PR front mount installed
Stock vs S2 IM
Studs from stock IM
IAC with bracket
Removing old gasket
Insert Hondata gasket & S2 IM
Install fuel rail & injectors
Reconnect Iceman intake and vacuum hoses
Ready to WOT!
Old Aug 16, 2004 | 06:46 AM
machine4321's Avatar
nice job ...did you notice a difference at all ....and were did you get the carbon sparkplug cover....i want one
Old Aug 16, 2004 | 06:50 AM
Behan's Avatar
Default Re: (machine4321)
nice pics.
when i read the thread title i was thinking s2000 IM, i was like WTF????
Old Aug 16, 2004 | 07:02 AM
Shakes's Avatar
space cadet
Default Re: S2 IM & PR solid mounts installation pics (VSBB6)
so what are your thoughts on it?
and the PR motor mount... sorry but what does PR stand for?
Old Aug 16, 2004 | 07:09 AM
Kal's Avatar
Kal
looks nice
Old Aug 16, 2004 | 08:10 AM
Nikoli's Avatar
Default Re: S2 IM & PR solid mounts installation pics (Kal)
pr = place racing?
Old Aug 16, 2004 | 08:32 AM
PreludeRacer023's Avatar
Default Re: S2 IM & PR solid mounts installation pics (Deckedlude)
are the PR mounts 4th and 5th gen i have energy suspension, and i keep tearing my drivers side mount which tell me that the inserts arent holding it as steady as they should be.....and im looking at the Skunk2 IM but i wanna see some people cars and possibly some dynos first...looks good though
Old Aug 17, 2004 | 07:13 PM
VSBB6's Avatar
The difference of these mods is night and day.
Vibration at idle is the first thing I notice, it takes some time to get used to. Once you stepped on the throttle its all good. Engine response has greatly improved, launching the car from stop is noticeably quicker than before. There is absolutely no wheel hop, every up shift is stronger and immediately bring the car to leap forward. I am starting to love these mounts I would only recommend this mod if you do not mind to sacrifice a little comfort.
As for the S2 IM, it makes my car screams at VTEC. It pulls hard all the way to redline. Low end power seems the same as before. Clearly this IM was designed for high end power and it does an excellent job.
Old Aug 17, 2004 | 07:43 PM
what about the spark plug cover
where you get it
Old Aug 17, 2004 | 07:55 PM
caLiH22A's Avatar
did you have to extend the IAC connection to be able to hook it up behind the manifold?
Old Aug 17, 2004 | 09:41 PM
sharkcohen's Avatar
Default Re: (VSBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">As for the S2 IM, it makes my car screams at VTEC. It pulls hard all the way to redline. Low end power seems the same as before. Clearly this IM was designed for high end power and it does an excellent job.</TD></TR></TABLE>
Get it tuned, post a dyno. Butt dyno doesn't mean ****.
Old Aug 17, 2004 | 10:06 PM
VSBB6's Avatar
Default Re: (caLiH22A)
Thats a Gemini valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A &raquo;</TD></TR><TR><TD CLASS="quote">did you have to extend the IAC connection to be able to hook it up behind the manifold?</TD></TR></TABLE>
Old Aug 17, 2004 | 10:08 PM
VSBB6's Avatar
The S2 IM comes with two vacuum tubes and brackets to connect the IAC so that can hook up in front of the manifold.
Old Aug 17, 2004 | 10:10 PM
VSBB6's Avatar
Default Re: S2 IM & PR solid mounts installation pics (Shakes)
Place Racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">so what are your thoughts on it?
and the PR motor mount... sorry but what does PR stand for?</TD></TR></TABLE>
Old Aug 17, 2004 | 10:12 PM
VSBB6's Avatar
Default Re: (sharkcohen)
No kidding, that was just my first three days driving impressions of the new parts. Dyno to be followed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Get it tuned, post a dyno. Butt dyno doesn't mean ****.</TD></TR></TABLE>
Modified by VSBB6 at 7:19 AM 8/18/2004
Old Aug 18, 2004 | 04:12 AM
93H22ACX's Avatar
Default Re: (VSBB6)
cool let us know
preludeNApower
Jan 12, 2012 08:35 AM
Con
Dec 9, 2010 11:58 PM
Powered by VTEC
39
Mar 5, 2008 02:23 PM
Boner_Ben
May 29, 2007 03:21 PM
accordking
Jan 31, 2007 06:59 AM
