Hasport Motor mounts installed. pics inside
it is really the pain in the butt to get the rear mount off when engine is still intacted.took me 1 hour alone to take it off.and installed it took me 45 mins. here are the steps of what i did.
i jacked up the car, put a support right under neath the back of the tranny and removed T bracket and then rear mount. with heater core in the way ,really annoying.. finally got the rear mount off..installation is just reverse.
front two mounts are pain too as hasport is really firm and there is not much room to move around the mounts. the whole job took me 3 hours to complete.
pm if u have any questions. and dont go cheap with mounts.u will end up buying a good ones and waste your time on swap them again.
Re: (instrument)
Appearance/Cosmetic stuff belongs in the Appearance/Cosmetics forum.
This is a tech forum.
In case you're wondering why those fall under appearance/cosmetic even though they aren't for aesthetics, it's simply b/c this post has no tech value, it's simply images, which makes it cosmetic, not technical.
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">How bad is the vibration at idle?</TD></TR></TABLE>
I remember when I had them on my eg with an itr swap. It was really stiff. Made the whole car shake at times. I would recommend getting inserts for the oem mounts vs the hasport if you're looking to stiffen it up a bit especially if you're not doing a swap.
Resident Gearhead
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">
I remember when I had them on my eg with an itr swap. It was really stiff. Made the whole car shake at times. I would recommend getting inserts for the oem mounts vs the hasport if you're looking to stiffen it up a bit especially if you're not doing a swap. </TD></TR></TABLE>
x2
Vibration is bad, and loud. I would only use the mounts for racing.
x2
Resident Gearhead
Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX »</TD></TR><TR><TD CLASS="quote">Weird. I have zero complaints about these mounts. I have no vibration at all. (GSR Ej8)</TD></TR></TABLE>
Really? Are you joking?
Former Moderator
Re: (HondamanXxX)
You've got to be joking.
I love HASport, but to say their mounts don't vibrate is just impossible.
Re: (B18C5-EH2)
I have the same setup - EJ8 with GSR - and vibration at idle isn't too bad. I also have the mounts with the softest inserts that Hasport makes, which isn't all that soft... durometer is 62A I believe. to the mounts though, I don't mind the vibrations at all. I suspect a lot of the complaints are coming from people with loud exhausts in addition to the mounts.
Resident Gearhead
Re: (B18C5-EH2)
I love HASport, but to say their mounts don't vibrate is just impossible.</TD></TR></TABLE>
Yeah I know, it's hard to detect e-sarcasm.
Re: (mcvtec)
i opted for Es inserts in the torques and hasport rear it vibrates a little but i am not complaining since i will never have to replace the others
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Appearance/Cosmetic stuff belongs in the Appearance/Cosmetics forum.
In case you're wondering why those fall under appearance/cosmetic even though they aren't for aesthetics, it's simply b/c this post has no tech value, it's simply images, which makes it cosmetic, not technical.</TD></TR></TABLE>
get out of here its people like you that ruins this place
Re: (jdmeg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 »</TD></TR><TR><TD CLASS="quote">
get out of here its people like you that ruins this place</TD></TR></TABLE>
He is correct though.
Anyway, nice mounts.
Syndacate is right though as he is about most of his posts, but gfg I couldn't listen to my cd player either in my EJ GSR. and yes, I'm suffering from infertility now</3
Re: (Syndacate)
this guy basically posted the similar thread as i did and the way u replied his thread is totally different than u did to mine. is it because he has more post as an old member or ??
here is the link
https://honda-tech.com/zerothread?id=2240473
here is the link
